Using a CB in the house & power supply question?
I want to ask about this in its own right as I can't seem to get a straight answer via Google without a lot of digression of unrelated info which as a new user to the scene is getting very confusing.
So at some point in the next couple of weeks I'm also looking at the option of also being able to use my Thunderpole 800 in the house. If only because the the idea of sitting in the car all the time just to listen can be off putting and if I can simply also set it up easily to use in the house then I know the missus will maybe use it whilst I'm at work.
Now this Thunderpole 800 when I bought it has the 12v (cigarette) adapter already connected for car use, likely soldered internally I'm thinking. So I'm stumped on my options to use it in the home. As in my into thread this was suggested as a suitable power supply for it to use in the house: https://www.ebay.co.uk/itm/175255358818 ... media=COPY
Yet as you can see, that's simply to connect the black & white wires into, so not really an option seeing as there is already a 12v car adapter moulded or soldered. So in that respect, what are my options to resolve this?. The only thing I've so far found is something like this which I'm wandering if it will work, even suitable at all or just down right dangerous for CB usage:
Basically I want an easy plug & play solution that allows a quick moving of car to house to use of it possible?.
- Buick Mackane
Re: Using a CB in the house & power supply question?
If you've posted a pic above it's not showing. Some power supplies have built in cigarette lighter type sockets, Although i couldn't name a particular model off the top of my head,
Or you could get a cigarette lighter socket and wire it to your power supply.
See link below
https://www.ebay.co.uk/sch/i.html?_from ... _PrefLoc=1
See link below
I've got something like this stuck on the top of my power supply and wired directly onto the outputs in case I need to use a cigaretter lighter plug:
- Buick Mackane
You could always visit your local scrappy and pull one from a scrap car if your really tight like me
Or if you prefer a power supply with a cigar lighter socket built in take a look at this
https://www.ebay.co.uk/itm/403023377945 ... R-iCuJ6kYg
- MrWeetabix
- Admin
- Call Sign: 26TM175
You could buy a new power lead from the radio...without cigarette connector on the end too
- Transwarp
- Call Sign: Viper
I believe your T-800 radio has a non removable power lead.Dave9946 wrote: ↑04 Jul 2023, 09:54 I want to ask about this in its own right as I can't seem to get a straight answer via Google without a lot of digression of unrelated info which as a new user to the scene is getting very confusing.
Plenty of power supply's that have 12v cig lighter socket built into them, or you can buy a 12v cig socket that it plugs into and in turn you connect the red and black wires that come from it to the power supply instead.
I suggest you buy power supply from a reputable retailer like Thunderpole, Nevada, Knights CB. If though you already have a PSU and just want a 12v socket you can buy from the places already mentioned or eBay / Amazon.
Yeah, certainly looks like the power lead is non removable which is part of my frustration, just don't quite get (though I assume there is an obvious reason to the experienced) why it needs to be 1 or those power supply box\units linked to above over something like this which is recommended for 12v car powered devices in the home?. https://www.ebay.co.uk/itm/10A-120W-Con ... ect=mobile
Not about the cost difference of 1 of those as such, but more trying to understand the differences & reason why those basic adapter leads can't be used?. Unprotected power control flow of something guess it will be?
- Buick Mackane
You could try one of those but it might be electrically noisy, Also it should really be 13.8 volts not 12.
- Transwarp
- Call Sign: Viper
CB radios are designed to run on 13.8 volts as Buick mentioned, brick adapters are 12 volts and are rubbish for that job so get a proper PSU for your rig otherwise if you use that brick adapter junk you might end up buying another rig when it goes pop - pay cheap buy twice.Dave9946 wrote: ↑06 Jul 2023, 09:22 Yeah, certainly looks like the power lead is non removable which is part of my frustration, just don't quite get (though I assume there is an obvious reason to the experienced) why it needs to be 1 or those power supply box\units linked to above over something like this which is recommended for 12v car powered devices in the home?. https://www.ebay.co.uk/itm/10A-120W-Con ... ect=mobile
12v socket.....
www.ebay.co.uk/itm/12V-24v-10A-120W-Car ... 5414104416
You want a 3 to 5 amp PSU which will set you back about £30. If money's tight maybe one of the forum members might have one to sell you cheap or even let you have something that they have kicking about in a spares box somewhere for nothing if you pay for the postage.
Certainly looking at getting the power supply, no real rush as such for that and more about research and getting it right first.
- Transwarp
- Call Sign: Viper
Unless planning on getting a more fancy radio that requires more amps, and / or using a linear amplifier, a basic PSU for your current radio is all need. Plenty of info about CB / ham radio PSU's on the web, and many knowledgeable folk on this forum who l'm sure would be happy to help with info on as well
These cost about £3, so Ican't see why it won't do the job and woukd take literally 5 mins to trim the wires and fit 2 terminal ends on insteadThe Collector wrote: ↑04 Jul 2023, 17:05 I've got something like this stuck on the top of my power supply and wired directly onto the outputs in case I need to use a cigaretter lighter plug:
- Call Sign: G4RMT
The Sherman power supply will be fine, so just source the cigarette lighter style connector and away you go. Sometimes it’s easier to source a cable with connectors on the end from places like Amazon, then cut off the unwanted connector, leaving the cigarette lighter style one. Just make sure the red terminal goes to the centre pin, not the surround, which goes to the black terminal. That’s it.
