Constant beating Pulse
Hi, I have just setup a simple home rig after 40 years away from CB Radio.
I have a DV27 mag mounted on top of a 40 foot container, using an old Communicator 27/81 and also a more recent Midland 38 27/97.
On receive there is a constant beating pulse about one beat a second, this is across all channels on both radios. Does anyone have any idea what this might be from? Also I have not managed to pickup any activity from other users.
I'm based in Stone Staffs.
Re: Constant beating Pulse
Breakers down. Radio from battery.
Is it gone?
Is it gone?
No, the battery supply is good its the same with both CB radios.
- Buick Mackane
There's a lot more electrical noise these days compared to when you last used radio 40 years ago. As above run your radio from a battery then switch off the power at the mains, if your lucky the noise will be coming from your own house.
Lucky you. It comes from your house.
So disconnect electrical equipment in your house one by one till you find what makes that noise.
Let us know what was that.
- Buick Mackane
I'd like to know more about the 40 foot container
If you can't get rid of the noise try PMR446 there won't be any noise of that band.
I did think about electrical items at home so I will try isolating them this evening.
Are you urban or rural? First thought for a 1hz pulse would be an electric fencer for farm animal control that is sparking to earth somewhere.
One person in ten understands binary, the other one doesn't.
As above, run a radio off a battery then turn mains switch off and see if it continues. If it does, it's 99% likely it's not on your property.
40 years ago I'd have said possible Russian "Woodpecker" over-the-horizon radar
- Call Sign: 26TM773
Powerline interference mostly caused by cheap Chinese tat and internet cables.
- NightProwler
- Call Sign: 163TM186
- Call Sign: G4RMT
Check the wall-wart type poser supplies and especially check the one on your internet. If you are using copper not fibre - the interference can be carried on the overhead lines. Other culprits are smart meters!
