New Antenna & Coax cable
Posted: 06 Aug 2022, 12:46
Hi,
Hope this is the right place for posting this.
After many years of building my own antennas of all sorts, I have decided to buy the ScanKing royal discone RX 20-2000MHz. I live in a block of flats in London and for the last 22 years, I have had about 20 meters of RG213U running from the roof to my shack.
I usually scan both civil and Mil airband but am happy to scan or try to decode anything from kHz to GHz, so I wanted to find out what you think about RG213U which seems to have an upper limit of 1GHz, and if a change of cable to an expensive cable like LMR400 would be really beneficial.
I would like to scan up to 6GHz with my HackRF, the councils seem to have their video links around the upper end of 5GHz (most likely encrypted).
I am also thinking of placing an LNA at the antenna which may remove the need for the new coax and compensate for the cable loss.
Since I will have to put up a proper mast I also got myself a 4-way electronics RF switch and an 18GHz RF relay, so I may experiment with placing some other GHz antennas and switch them into my coax.
So a bit of a project, I dont particularly want to spend a lot of money on a coaxial cable that it may not make much of a difference or if an LNA would fix it, so I am open to your suggestions and pointers.
Thanks,
Thanks,
