Hi guys 26 years after putting my hygain 5 2795dx in a box it has seen the light of day again and I am in the process of setting everything back up , the question I have is what channel and setting is what frequency I used to know it off by heart but for the life of me can not remember how to find 27555 on it so if any one can shed some light it would be much appreciated until I can find a frequency counter
Many thanks
Scott
Hygain 5 2795dx channels and frequencies
- Call Sign: 26dt3204
- Ur5by9
Re: Hygain 5 2795dx channels and frequencies
Google says this
GENERAL
Type: Citizen band / "Freeband" / Export transceiver
Frequency range
depending on version: 26.965-28.305 MHz in three bands (Early version)
Low: 26.965-27.405 MHz
Mid: 27.415-27.855 MHz
High: 27.865-28.305 MHz
26.515-27.855 MHz in three bands (Later version)
Low: 26.515-26.955 MHz
Mid: 26.965-27.405 MHz
High: 27.415-27.855 MHz
manual with channels listed
http://www.cbradio.nl/hy-gain/Manual_hy ... 95_ENG.pdf
GENERAL
Frequency range
- Call Sign: 26TM773
Mine is channel 12 on mid band, but if yours is the later one it will be high band, still channel 12 though and USB of course.
- NightProwler
- Call Sign: 163TM186
I could be wrong but wouldent 555 be channel 52 on the Hy-gain? Long time since I owned a Cybernet radio.
Yes, it would be if on mid band, sorry.
I've got a UK board in mine which resets each band to 1-40.
Thanks guysNightProwler wrote: ↑16 Jun 2022, 15:38 I could be wrong but wouldent 555 be channel 52 on the Hy-gain? Long time since I owned a Cybernet radio.
52 does ring a bell ! I don’t think I have a channel 12 in usb / high will check Monday suppose I just need some skip to find out
I also remember my local cb shop did something to the NB switch to give me extra channels and I had it all on a chart but that’s long gone
