Cobra 148 gtl DX same power on all modes
Morning all,
Wondering if anyone has any advice on an issue I have with an old 148 gtl dx.
Symptom is SSB and AM/FM are all roughly the same power output.
The ALC control does work, as does everything else really, just can't get more than whatever I set AM as for SSB.
The radio was a auction site scrappy special, parts or not working, and when it arrived, the AM/FM was cranked to max (maybe this fault was already present), final blown, and regulator not too happy either.. so replaced them and now AM can be turned up to 9 watts or more, so think all that stuff is healthy.
I did read about a fault with a burned out track that can cause this symptom after a reverse polarity, but I don't think this radio has had that and I can't see any burned tracks or components.
Is anyone aware of this fault and have any areas to take a look at?
Re: Cobra 148 gtl DX same power on all modes
What's the voltage on the collector of the driver/final on SSB ? You should have about 5V on AM/FM and 13.8 on SSB .
Thanks for the replycb4ever104 wrote: ↑10 Jun 2022, 07:20 What's the voltage on the collector of the driver/final on SSB ? You should have about 5V on AM/FM and 13.8 on SSB .
About 5.5V on both AM and FM so guess that's the reason for the AM/FM level power output on SSB, just not sure why and I don't think I've had it before where AM power control affects SSB before.
whoops, I just measured again, properly.
5.5V AM, 9V SSB. Still not full voltage though....
Nick
Nick
You should be getting the full 13.8V on SSB on the collectors . I presume it's a mk 2 ? If so , then check TR52 first , to make sure that it's switching as it should , and then TR51 . There isn't really much more to that circuit .
Thanks Sammy,
Will check in the morning and post back.
Nick
Nick
Wrong. It should be PS voltage minus V drop (0.7V) on C-E junction.
I bet there is a drop on fuse and lousy DC connector too.
My calculations were made assuming that his PSU was outputting 14.5V , so my statement is correct.
Thanks guys. All sorted.
someone had stuck a different transistor in TR52 and it was dead. Replaced and putting out what it should.
Cheers!
Cheers!
