Dear forum members
I have a yagi marine aerial
But the bit that holds the coax connector
Is it called a balun
Marine yagi connector or balun
Re: Marine yagi connector or balun
And?
You’re and didn’t make sense
When you connect balanced antenna to unbalanced feeder you should (must) use a balun.
Ow I see
Well my aerial firm resent the balun but instead of been connector just at End of balun
Aerial firm put it on end of some type of five foot coax or thin pipe
Witch means when I get reconnected
Because of five foot pipe thing .
I’ll have to tell aerial erector to connect coax on the
Poor in the chimney
Poor in the chimney
