Chrome Paint For Bezel
- Call Sign: 26TM111
Hello all, as above has anyone had any success using chrome paint on their bezel?
- Mudslinger
Re: Chrome Paint For Bezel
It will never look like real chrome, but the best stuff I found was Humbrol Chrome enamel from a local modelling shop. Pretty sure that you get get it from ebay as well.
Cheer Simon i`ll take a look
Be aware though that it's quite fragile stuff and will mark easily compared to "normal" pain,t. It's usually marked as " For decorative use only" on most cans. It also won't be as good as it looks on the lid!
The best stuff is that water-based 2-coat stuff you'll find on Youtube. That's much harder-wearing and available in spray cans...although it's quite expensive if you're only spraying 1 item.
Here's one of mine from a few years back. Still got it just in case I need some Xmas tree baubles spraying
Thanks for your reply collector, that stuff on the tube really does look good, i have some flaked paint on a 360 bezel, i may start with a cheap brush on paint and see how it looks and take it from there.The Collector wrote: ↑29 Mar 2022, 15:44 Be aware though that it's quite fragile stuff and will mark easily compared to "normal" pain,t. It's usually marked as " For decorative use only" on most cans. It also won't be as good as it looks on the lid!
Shake well and spray some of that "chromalike" spray paint (as it was originally called in the 80's) into the can's lid and use a small artist's brush to dab some paint on the missing bits. Leave for about 4hrs indoors and dab a bit more on so you build up the paint in layers until it's the same thickness as the chrome. If it looks good enough, job done.
If it looks pants, then you'll either need to strip the surround down completely (a pain of a job unless you've got a plating machine and chemicals to remove the chrome) and get it re-chromed, or source a better surround.
I've done it before and it's better than having green or beige plastic showing, but when you get within a couple of foot you'll still notice it somewhat.
Thanks Collector, your brush and cap method is one option i have considered, i have since found this for another option possibly? has some ok reviews on the web.The Collector wrote: ↑29 Mar 2022, 19:26 Shake well and spray some of that "chromalike" spray paint (as it was originally called in the 80's) into the can's lid and use a small artist's brush to dab some paint on the missing bits. Leave for about 4hrs indoors and dab a bit more on so you build up the paint in layers until it's the same thickness as the chrome. If it looks good enough, job done.
https://www.ebay.co.uk/itm/253242201892 ... 1438.l2649
cheers
I think I could even use that !cooper wrote: ↑30 Mar 2022, 10:18 Thanks Collector, your brush and cap method is one option i have considered, i have since found this for another option possibly? has some ok reviews on the web.
cheers
All that thought of painting gives me a headache . And that's without the fumes
Give it a go for that price Put some before & after pic's up on here so we can see the results too. You never know, it might do the job nicely. Missing bits of chrome is unsightly, so if it does a decent job, one pen might do dozens of radios.
I'd do a test piece on something first so you get the flow rate controlled and don't dollop too much on...and have it run down the front of your radio overnight lol.
You can then test it after a couple of days in the warmth for resistance against abrasion or gentle scratching. If it marks easily then perhaps that's not going to cut the mustard.
It does look worth a puntcb4ever104 wrote: ↑30 Mar 2022, 14:19I think I could even use that !cooper wrote: ↑30 Mar 2022, 10:18 Thanks Collector, your brush and cap method is one option i have considered, i have since found this for another option possibly? has some ok reviews on the web.
cheers
i`ll order one up, and report back with some pictures in due course.The Collector wrote: ↑30 Mar 2022, 17:52 Give it a go for that price Put some before & after pic's up on here so we can see the results too. You never know, it might do the job nicely. Missing bits of chrome is unsightly, so if it does a decent job, one pen might do dozens of radios.
cheers
Yeah . Let us know how you get on .
S.
The verdict is not bad, i tried the above pen on a piece of plastic first and let it dry for around 24 hours, it dries quite hard but the shine can be rubbed off with my finger nail with little pressure. So i think it is ok as a touch up pen but it will not provide a smooth flat finish and larger areas brush strokes are visible.
Sorry for the poor picture quality
That looks ok to me. I'll buy some next time I see it.
I`ll post some more pictures of the completed bezel
