Radio chassis screw female rivet / rivnut thingies???
Hey all.
What's the technical name for these things pictured below please?
I have a Cobra 148GTL-DX that I'm going to be putting back together shortly and the chassis is missing a couple. I haven't any spare radios to rob any out of, so are there any companies that sell these?
Failing that, could anyone sell me a few if they've got a spares-bin radios or some new ones at all?
Ta.
Ta.
Re: Radio chassis screw female rivet / rivnut thingies???
I have the same problem Dave on one of my radios . I presume you need some kind of tooling equipment to fit them ? I've no idea what they're called though .
They only push in and the screw opens it upcb4ever104 wrote: ↑21 Mar 2022, 12:43 I have the same problem Dave on one of my radios . I presume you need some kind of tooling equipment to fit them ? I've no idea what they're called though .
DELETE MY ACCOUNT
That's it exactly, a bit like a rawlplug in effect. There's a slight squareness to them that stops them turning when the screw is tightened by the looks of it.Edd200sx wrote: ↑21 Mar 2022, 13:39They only push in and the screw opens it upcb4ever104 wrote: ↑21 Mar 2022, 12:43 I have the same problem Dave on one of my radios . I presume you need some kind of tooling equipment to fit them ? I've no idea what they're called though .
One of them was missing completely and another had snapped and the snapped off bit was inside. I tried some solder on it but it doesn't want to stick to it, so it would probably need a lot of heat. Even then, forcing a screw into it may shear it off again.
They're probably only pennies, but it's knowing what they're called or where to get a pack from. The only spare rig I have is an old GE radio and the screws go directly into the chassis, there are none of these plug things.
Typically, I sold a Uniden chassis on ebay a few weeks ago. That may have had some of these bloomin' things in!
Thanks for the clarification.
- 14CS06
Sorry . But are you sure that's the case ? I don't think tightening the case screws would press these enough . It looks to me as if the rounded raised side has been slightly pressed in the factory to stop it falling through .
Those are different to the ones on mine in the top picture. Perhaps they changed them due to the fact that they are a bit crap?
I'll take a pic' of the other side after I've taken my daughter to Brownies.
Pic's
Not sure how early or late it is board-wise? Says sel no. 00034 on the side of the chassis on a sticker for alignment procedures etc???, but it had a SS360 plate stuck over a used (sadly not untouched) GTL-DX plate.
Ahh. Ok. Sorry. Mine is a Ranger , so different from your Uniden.
There are a couple of ways to add things that'll accept an m3 screw, but it'd be a lot easier if someone had a few original ones lying around or knew where to get some from
- 14CS06
Thought I'd have another play with rivets, but not that good. They'd be a good thickness. However, drilling out the "stalk" from the inside of the rivets loosens them slightly so then they might spin. I was going to tap a 3mm thread in one but there'd be very little material left, weakening it.
Those are the same Claude
RTI has got a scrap Cobra 140 chassis, but at £50 just to get some of these plugs, I think I'll give it a miss.
Looks like I'll have to buy a £14 rivnut kit if no one's got any going spare.
- Auldgeek
- Call Sign: GM0BRJ
I have a scrap chassis here that you can have. I'll post some pictures shorrtlyThe Collector wrote: ↑22 Mar 2022, 10:51 Thought I'd have another play with rivets, but not that good. They'd be a good thickness. However, drilling out the "stalk" from the inside of the rivets loosens them slightly so then they might spin. I was going to tap a 3mm thread in one but there'd be very little material left, weakening it.
Auldgeek - Drew
