Central /queen street station Glasgow ?
- Call Sign: TV54
Hi does anyone know the central station or queen street station frequencies and colour codes? If they use digital or just normal fm mode ?
- Metradio
- Call Sign: G7HID
Re: Central /queen street station Glasgow ?
For someone with all the receiving gear you don't seem to have a lot of luck..GlasgowTransmission wrote: ↑09 Jan 2022, 10:26 Hi does anyone know the central station or queen street station frequencies and colour codes? If they use digital or just normal fm mode ?
Mike
Or just lazy.
Frequencies very busy so search the UHF band and you will find them within a few minutes. Then report your finds to the group perhaps?
Hi Glasgow Transmission
These frequencies used to be in use on FM a few year back.
Central Station 453.900
Queen Street 453.550
ctcss was in use on both.
Not listened in some time but good for a starting point although they may well be Digital comms now.
Most organisations i have dealt with usually keep the same frequency if they move from Analogue to Digital so bear that in mind.
Have a listen and let us know.
- Call Sign: TV54
Now that’s more like it , thanks mate one of the decent ones on this who actually help like this group is supposed to help for , I mean it’s a discussion page for this sort of stuff unlike some members. Thank you , your the type of people this page needs
Did you go to Central and Queen Street and search as suggested? Several freqs to be found at each station in range 453-462.5. I see that that two have have been suggested for starters so await your report to the group.
Unfortunately (and I have 1st hand experience of this) companies are monitoring what is being discussed as these forums are findable in Google searches, leading to places going encrypted as a result of it.GlasgowTransmission wrote: ↑22 Jan 2022, 20:09 Now that’s more like it , thanks mate one of the decent ones on this who actually help like this group is supposed to help for , I mean it’s a discussion page for this sort of stuff unlike some members. Thank you , your the type of people this page needs
Less and less is being disclosed in open forums because of a minority causing a nuisance on licensed frequencies leading to users using the encryption level.
Sign of the times unfortunately
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Very ture and I have experienced the same.scottyboy wrote: ↑09 Feb 2022, 13:06Unfortunately (and I have 1st hand experience of this) companies are monitoring what is being discussed as these forums are findable in Google searches, leading to places going encrypted as a result of it.GlasgowTransmission wrote: ↑22 Jan 2022, 20:09 Now that’s more like it , thanks mate one of the decent ones on this who actually help like this group is supposed to help for , I mean it’s a discussion page for this sort of stuff unlike some members. Thank you , your the type of people this page needs
Was at central tofay and queen street they use dmr Motorola handsets
all still fm, no dmr in central or queen street. I passed through both stations today.
Avanti also on the same as ScotRail, not dmr
- weegeordie
- Call Sign: 108TM020
Anytone UV878II plus
Inrico T320
Nemo Me Impune Laccessit
Inrico T320
I was last in Glasgow the day the queen died, both stations still nfm.
I gave these 3 frequency’s a listen today
453.550 Glasgow Queen street NFM
453.900 Glasgow Central DMR
453.100 Queen street or central barriers NFM
Not sure why central has DMR and NFM users in the same station maybe for different parts of the station
