Nagai superstar 3900 freq plan p!ease
- Call Sign: 45
Recently bought a 3900 Nagai I believe same as ss 3900 .has a red channel display a,b,c block and a high low switch.
I don't yet own a freq counter and am unsure where these blocks abc go and obviously then where again with high low switch.
Not yet located a 10kc switch either or may not be one.
Could someone please point me in the right direction 're a freq chart plan so I can navigate.
Thank you
Thank you
- 14CS06
Re: Nagai superstar 3900 freq plan p!ease
- Call Sign: 45
Ah thank you that's is excellent.much appreciated. Merry Christmas claude
Would you happen to know who manufactured the Nagai version and where please country of origin. Not a lot of info on this brand name
Thank you again
Thank you again
- 14CS06
Hello
Country of origin Spain
Other model Nagai
SS-290
CB-290
Nagai Saturn
Other model Nagai
SS-290
CB-290
Nagai Saturn
- 14CS06
- Call Sign: 45
Thank you again , not seen any of those radios ever and wasn't aware of the brand name.
All the best
All the best
It was made by Ranger (for Nagai) . Manufacturing country will be marked on the back. Taiwan or Malaysia.original45 wrote: ↑20 Dec 2021, 22:29 Thank you again , not seen any of those radios ever and wasn't aware of the brand name.
All the best
S.
- Call Sign: 45
Thank you , nothing marked on back 're country of manufacture which I was surprised about.
A couple series numbers that's it.
I found it strange it had dimmer printed under abc band switch but no dimmer and appears to have cw but it's not printed on bezel .
Really no expert here but seems to have a fair receive, quite audio so far but the board does look well made very clean .
Will need a 're alignment as it's slightly high usb and lsb is no better in fact worse in told.
Going to look see if theirs a owner's user manual I line latter to ptintoff although didnt find one yesterday.
Swr can switch is duff too.Will pull out feel loose put takes 5 mins to get it back in again .grrr.
Cheers all.
Cheers all.
- 14CS06
Hello
Please insert some pictures
If there's nothing on the back , then it's probably Malaysia . Look for the Ranger pcb number on the solder side . EPT3600XXX. Might be a 13 , or 14B . You can get the date of manufacture (more or less) from the PLL , or other ICs . WWYY . Example . "2593" will be week 25 of 1993 . I'm not 100% sure of the exact switch of factories , but anything +1994'ish is Malaysia .original45 wrote: ↑21 Dec 2021, 09:17 Thank you , nothing marked on back 're country of manufacture which I was surprised about.
Cheers all.
The DIMMER is common here . The radios weren't allowed to have the bands marked when they were imported into Spain . So the decal was either changed , or a sticker marked "DIMMER" was put over it . The sticker is mostly on the Presidents .
- 14CS06
Hello
Owner's manual Super Star 3900
http://www.servicedocs.com/ARTIKELEN/7200208240001.PDF
- Call Sign: 45
- Call Sign: 45
- Call Sign: 45
Malaysia. The power connector at the back is a giveaway too.
