TAIT T2000 series 1 radio errors
Here you can discuss Datamodes for all bands (PSK31, FT8, JS8Call, etc), Software Defined Radio topics & General Radio Software or apps
vk1kv
Call Sign: vk1kv
Post by vk1kv »
Hi All, I have a couple of T2010-321 one is a series 11 and programs ok.
The other a series 1 give the following error: "The radio type and database version are incorrect for this product"
I have tried the V3 S/W and the older DOS PGM201X S/W, both give the same error.
Radio Type : T2010
S/W Version : STD 0103
DB Version: 0101
Any thoughts?
Dave
26mb04
Call Sign: 26DG01
Re: TAIT T2000 series 1 radio errors
Post by 26mb04 »
Have you tried resetting it? The reset procedure is on here somewhere, it involves taking out the battery-backed IC and powering up the radio. I haven't programmed these for ages, I remember the radio version (model I, II etc) and software MUST match or it won't work. Is it a trunking version? The trunking rigs require the trunking software, regular one won't work.
Sent from my GP300 using DTMF
