AnyTone AT-D868UV Talkgroup audio issues
specializedrider
Call Sign: MM7BCG
Post by specializedrider »
Hi everyone
I think this is a common issue, but I’m stuck trying to figure out how to fix it. When I am listening to a talk-group the light is green but no audio will come through and the contact is not displayed on the screen. If I push the monitor button then it activates the talk-group and I can listen again but I have to do that every time some is talking. I have set static talk-groups but even before setting static talk groups this was an issue at times
Thank You
AnyTone AT-D868UV
Raspberry Pi3 MMDVM with Pi-Star
Alan Pilot
Re: AnyTone AT-D868UV Talkgroup audio issues
Post by Alan Pilot »
With mine setup is the same as yours i don't get anything until i key the ptt just for a split second then it is ok all day after.
