Hi,
President Lincoln 1st gen key beep; is there any mod to switch this off?
It's annoying loud
btw I'm no talking about the Roger Beep
Cheers,
- Call Sign: 26TM5890
Elecraft K2
President Grant II Premium
Re: President Lincoln 1st gen key beep
J302 on PLL board. Remove cable nr 9 and no more beep.
- astradyne
That must be a very early Taiwan Lincoln. With the second run onwards (made in the Philippines) the key beep was much quieter and adjusted with the volume control. Much easier on the ears.
I presume it's had the talkback removal mod done.
it's indeed a Taiwan 1st gen
have cut the wire for now but might do something else as i don't mind a beep on a very low volume
Elecraft K2
Found in the past uncliping the brown wire makes the 1st gen (mk1'') chann selecter do strange things' when clicking the bands below 28 megs(26 megs- floating volts'', unsolder 1meg resistor, sub say 270k that goes to pin 33 on cpu board.
After looking on Lincoln cpu, R391- 100K
