I've been wanting to do some 6 meter projects I want to build or convert transceivers to 6 meters for fun. I know that this side of the hobby is pretty much dead now as nobody builds there own kit anymore or at least not very many people do at all.
I don't have anything for 6 meters and I don't plan on buying an expensive transceiver just to get on six meters either. I'd much rather have fun building my own 6 meter transceiver. Some people will say why 6 meters? the band is dead blah blah blah. Its for fun and six meters is a nice band to start with in regards to building a transceiver and I'd have a cool rare 6 meter transceiver by the end of it. I think this will be an exciting fun project.
When looking for suitable transceivers to use for my project I've found that there literally isn't very much out there for 6 meters. I know of some single band 6 meter transceivers that exist such as the AKD and a few others. I know of a Motorola transceiver that will cover 6 meters but is more commonly found stateside than in the UK. All these transceivers are rare and expensive.
First I want to talk about modes. FM/SSB are what I want plus I want something where I can use 6 meter FM repeaters. I plan on building two separate transceivers, one for FM and one for SSB.
I would like to start with the FM transceiver first.
I was thinking about using a suitable FM CB radio for this but for repeater use it will get a bit complex but still doable. I would however like to keep things simple. I will need something that can transmit on one frequency and receive on another with CTCSS. An FM CB radio may not be ideal for this. An ex-business PMR Transceiver would be perfect for this with a transverter, I'm not looking for anything with hundreds of channels it only needs to be something like an 8 channel or more VHF FM transceiver on 2 meters with a transverter board to go from 145 MHz to 50 plus MHz. I will have about 4 repeater channels and a selection of 6 meter FM simplex channels.
I want to work on the FM 6 meter transceiver first and I'll come back to the SSB side later.
If I were to go down the CB route I don't think there would be enough room for the extra boards to fit inside an average CB radio. I want it to be a tidy project without external boxes on the back of the transceiver.
Things that I have:
49 MHz walkie talkie
CTCSS tone boards
Old CB Radios
Suggestions? Ideas?
6 Meter Projects
Re: 6 Meter Projects
There was a project published on the web - conversion CB radio to 6m.
GL with your project.
- Werthers
Thanks. I have been reading quite a few threads online about it. There are a few interesting transverter schematics with printed PCBs for making the circuit board that I'm probably going to build if all the components needed are easily obtainable.
- Werthers
Just an update. I've put this project on hold for the moment. My plan is to build the transverter but first I need to get my other projects done. I have downloaded all the info I need for the time being. Next step will be making sure I can get all the required components I need for the build.
