RM KL703 Reviews?
- Call Sign: 29SC01
RM KL703 Reviews?
Hi has anyone used the above amplifier? Any thoughts, good or bad. Is it worth getting or is there better ones to be had that would be of the same wattage more or less?
Re: RM KL703 Reviews?
I’ve got one seems to work well.
Pretty sure it’s the most powerful 12v commercially
Available at the mo
Available at the mo
DELETE MY ACCOUNT
- gmham
- Call Sign: 108TM154
Sure there are a couple of reviews on YouTube . Lovely amp but obtaining a suitable psu to run it at a reasonable price is the problem !
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- gmham
That’s better than I thought. Got any links ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- gmham
Cheers mate appreciate that.Edd200sx wrote: ↑20 Apr 2021, 07:14 Easy
https://www.nevadaradio.co.uk/product/nevada-psw-50/
https://www.hamradio.co.uk/accessories- ... pd-702.php
What sort of output powers are you getting for a given input ?
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
- gmham
You tested out the swr on the radio side when using linear ? one owner reporting a 2.0 swr with the linear .
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
30w around 430w outgmham wrote: ↑20 Apr 2021, 07:39Cheers mate appreciate that.Edd200sx wrote: ↑20 Apr 2021, 07:14 Easy
DELETE MY ACCOUNT
- gmham
Okay thanks mate. Will keep an eye out for a used one at a decent price.Edd200sx wrote: ↑20 Apr 2021, 19:0930w around 430w outgmham wrote: ↑20 Apr 2021, 07:39Cheers mate appreciate that.Edd200sx wrote: ↑20 Apr 2021, 07:14 Easy
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
I doubt it will be cheap even second hand. The retail has even
Gone up recently on them
DELETE MY ACCOUNT
- stanogs68
- gmham
This is another owner mention about the high swr problem, can’t find the other owners post on FB but this is someone else reporting similiar. Yours okay ? Possibly just a batch that were built having this particular issue ?
HIGH SWR ON RM KL703......The RM KL703 is a great Amplify very well built in my opinion. Only One Snag is the high SWR it shows the Radio on high Power. To remade this add a chunky verible Capacitor (marked with Yellow Circle) to the input of the first Inductor to Ground. Then monitor the SWR on the Radio & adjust the Capacitor until SWR comes down & it's possible to get a standing Needle. . You could use fixed value Capacitors but you would have to experiment with different values. Sorry i don't know the value of the verible Capacitor but obviously RM didn't use enough Capacitance in the surface mout Capacitor that's installed.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
No I don’t get any swr issues at all 1.12 at 300w
gmham wrote: ↑07 May 2021, 10:12This is another owner mention about the high swr problem, can’t find the other owners post on FB but this is someone else reporting similiar. Yours okay ? Possibly just a batch that were built having this particular issue ?
DELETE MY ACCOUNT
