2 RADIOS RUNNING ON 1 ANTENNA IS THIS POSSABLE?
- WARLOCK
- Call Sign: 26TM134
i have just put a discone antenna up on a 20ft pole i am wondering if i can run a ( UBC125XLT and UBC785XLT ) from one discone antenna ?.
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: 2 RADIOS RUNNING ON 1 ANTENNA IS THIS POSSABLE?
You'll get some signal loss, but for RX that should be fine.
I ran 2 for a long time on a scanking discone never noticed any problems.
- bigpimp347
yes but you will suffer from interactions.
one scanner may steal more signal than the other..
you could use a simple satellite TV splitter to get equal to each radio,
or buy a VHF/UHF TV antenna booster with twin or more outputs and use that, you have a built in amplifier and proper splitting.
- WARLOCK
THANKS MARK will try the TV antenna booster
- stanogs68
thats a great idea ,is that like a preamp and could you in theory use it on a cb radio ?
love your familly
- Call Sign: G4RMT
It's a pre-amp, but of course one way - transmitting into it would be a pretty bad move.
- Metradio
- Call Sign: G7HID
I use one of these to run multiple scanners on the same antenna:
http://www.crosscountrywireless.net/multicoupler.htm
Mike
Mike
Years ago I used to mod the filters on uhf tv distribution preamps to open them up for dual scanner use, it did work as Mark says.
W8JI
- Andy
Watch it - modern TV pre-amps tend to be band-limited and only work over the range 450 to 800 MHz. I'd go for a passive satellite splitter and accept the small loss.
'SOMEONE GET ME A SAW!'
Andy.
Andy.
Hello,
If just scanning then yes it would work.
In my old set up I ran quite a few scanners from two homebrew civ/mil aerials all
linked together using just T pieces on the coax/patch leads. Seemed to work good to me.
andy5600
