Fancy trying out a tetra decoding software with my rsp1 / sdr# but before I do is there much unencrypted tetra signals around the Fife / Edinburgh area ?
What type of user uses tetra over DMR ?
Tetra decoder- any activity ?
- gmham
- Call Sign: 108TM154
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- Metradio
- Call Sign: G7HID
Re: Tetra decoder- any activity ?
Non Airwave Tetra tends to be used by a number of underground railway systems i.e. London Underground, plus a tram system in Nottingham...
Don't think there is anything around Fife/Edinburgh..
Mike
Mike
- gmham
Okay cheers Mike maybe won’t bother then ! To be fair out with the emergency services you don’t hear a lot about it so you.
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Kenwood TS711e
Anytone D578UV Pro+
I work security at a few of the Covid Test Sites in Edinburgh and we use Hytera radios i'm not sure but are they TETRA radios?
Whistler TRX-1
- Metradio
- Call Sign: G7HID
Doubt it, Tetra is designed for expensive multi slot trunked radio systems, a bit over the top for event security..
Hytera make all sorts of radios, they have a model designation on them, from that we can identify mode and frequency band..
Mike
As Mike says, I very much doubt it's TETRA either. Switch it off, pop the battery off for a second, have a look at the model number, tell us what it is. It'll likely say frequency band as well. I'm willing to bet it'll be a PD5 or PD7 model. A TETRA subscriber model will be a PT model.
Sorry guys wrong radio completely we use Sepura SBP8340
Whistler TRX-1
- Metradio
- Call Sign: G7HID
Possibly using simplex on Uk general or short term hire frequencies
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
