Firstbus frequencies Glasgow ? For a digital scanner
- Call Sign: TV54
Does anyone know the first bus frequencies in Glasgow to pickup from a digital scanner model sds100 ?
Re: Firstbus frequencies Glasgow ? For a digital scanner
They used to be around the 180 to 200 MHz area if I mind correctly, using an analog MPT1327 trunked network.
Not sure if still using that as been a while since I scanned that band.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
