I have a business channel which has 2 talk groups both using the same colour code. Can I programme my pd785 to allow both talk groups through on the same channel?
Hytera pd785 1 chan 2TGs
Re: Hytera pd785 1 chan 2TGs
If both are on the same frequency and timeslot (if it’s a repeater) then you you can add both talkgroups to the rx list and you would get both on the 1 channel
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
the thing is, off all things frequencies there are, I have both a local shopping centre and the local shoplink on the same frequency, both simplex. The only difference between them is one is TG 10 and the other 20. I want to have one entry for each.
I have put TG10 and TG20 into my CPS but I am not getting the option to put them in the RX group list which I guess would differentiate between the two. Another option is to have them on the same channel but I'm not sure if the Hytera will allow 'Any talkgroup' through or how to do that (Rx group list: none?)
