Fire Alert Pagers
ANCIENTMARINER
Fire Alert Pagers
Post by ANCIENTMARINER »
Hi,
Can anyone tell me if 147.8MHz is used in Scotland for fire brigade call outs ?
TIA, Al
Doombar
Re: Fire Alert Pagers
Post by Doombar »
Yes. I monitor it regularly.
457,489Mhz is the default fire ground channel (Channel 3)
spykeboi
Call Sign: 2M1SB
Post by spykeboi »
Doombar wrote: 17 Nov 2020, 20:47 Yes. I monitor it regularly.
Is there much activity on the fire pagers?
Doombar
Post by Doombar »
If your local fire service is on the retained duty system, volunteer or day manned they can be very busy during peak wildfire season.
scottyboy
Post by scottyboy »
How is it set up, is it wide area so a blanket signal for certain pagers or is it localised for which ever station they are paging for?
Where I live there is mainly whole time stations but retained stations about 8 - 10 miles away.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
spykeboi
Call Sign: 2M1SB
Post by spykeboi »
Doombar wrote: 20 Nov 2020, 19:37 If your local fire service is on the retained duty system, volunteer or day manned they can be very busy during peak wildfire season.
Is it regional or nationwide messages you get on the frequency?
Doombar
Post by Doombar »
Regional up to about 20 miles distance. Tone only. Three bursts at a time.
spykeboi
Call Sign: 2M1SB
Post by spykeboi »
Doombar wrote: 25 Nov 2020, 23:12 Regional up to about 20 miles distance. Tone only. Three bursts at a time.
Thanks!
