Yeticom Optima radios any good
- WARLOCK
- Call Sign: 26TM134
How do you rate the Yeticom Optima radios, I had a yeticom optima some time ago and thought it was a very good radio ,Now some years later i have bought another one and i am having second thoughts about them , Has anyone else got or have had one if so how do you rate them ???
Re: Yeticom Optima radios any good
Just a CB, nothing fancy.
Keep in mind, that not longer manufactured and limited spares/service possibilities in EU.
- Mudslinger
They work well but the build quality is pretty poor.
I would rather have an Anytone type radio personally.
- Otter
- Call Sign: 26TM439
I have one here with modulation issues - like no audio on any mode. I've never managed to find a schematic for one.
- 14CS06
Hello
https://dd182003.wordpress.com/2010/04/ ... nder-test/
https://dd182003.wordpress.com/?s=Yeticom+Optima+
http://yeticom.samson-tiara.co.id/how%20to.html
From blog 91DD018
From blog 91DD018
- Auldgeek
- Call Sign: GM0BRJ
I've owned a couple but terrible build quality.
Auldgeek - Drew
- ROTEL240
As above they fo work very well, no daft colour changing screen no echo etc but the build quality isn't great, if I was buying a 11m radio I would now go for the ss6900 Mass dx5000 type as they seem to be better built.
- JibberJabber
I’ve had a few over the years.... With different results... The first one I bought was a MK1 from the then Radiozing... I have to say it was spot on and quite honestly the best mulitimode I have ever had... Its only downfall was quiet audio on fm... But hey on SSB it excelled.. I had loads of contacts on 10,11 and 12 and all with good reports ... I did use a Japan made HM-36 with it which made a significant improvement over the stock mic.
Only sold it as I bought a Yaesu FT-897D... I have always regretted it ... Since I have had a few more and all have been no match for the original.. I had a MK3 that had clearly been used before or been back for ‘tweaking’ This again was from Radiozing .. Sent that one back and had a couple that had gremlins...
In the end I decided to bite the bullet and go direct to Yeticom... Cost a bit more but I thought at least I would get a good one.... Unfortunately the one I had would lose power as you were talking and only part of the transmission would be received... To be fair Yeticom refunded me immediately .... But really all I wanted was a working one... So pretty much gave up after that.
If I could have my original back I would.
If the quality control had been on top of things this should have been a great wee radio ... But in the end .... Hit and miss ...
Jason
Jason
- Call Sign: 26TM1609
I've had a MK3 from radiozing from new, never had any issues with build quality. I also purchased the HM-36 mic, had no problems with the audio. Still does 50w out the back. Found it works really well mobile.
Try owt once, twice if you like it
- astradyne
I have a V2. It's the first Optima I've used/owned and I'm pleasantly surprised. I got it a couple of months back and always good reports on SSB.
It came with a cheap Chinese copy ICOM HM36 mic which, believe it or not, suits the radio perfectly (link below).
I must say I like the radio. Perhaps, as is often the case with modern radio's, it comes down to the luck of the draw as to whether or not you get a good radio. Both build and quality control serms very hit and miss.
https://www.ebay.co.uk/itm/202365763095
- prettypolly
- Call Sign: 26FB185
Wasn't there a mk2b
- ROTEL240
Yes there was mate less than 100 made I did own one, the number 4 button was upgraded to memory scan and the vfo knob was labelled VFO instead of channel. All mk2 Optima serial numbers started with #64****.
- astradyne
Indeed there was. You'd be very lucky to find one though as less than 100 units were sold.
- JibberJabber
If you go on the Yeticom website they give you a guide to the different versions ...
- WARLOCK
HELP NEEDED has anyone got any idea how to wire a microphone for a yeticom optima with a 8 pin plug fitting ???
