Air Band question
AMX97
Air Band question
Post by AMX97 »
I've been hearing loads of military specific chatter on these frequencies does anyone know if they are predominantly used by the military or is it just frequencies that everyone seems to use... i was in and around Birmingham on the days i heard them if that helps.
0122.4166
0108.6500
0129.3500
0124.1750
0129.2916
0124.3750
0134.3916
0126.2250
0133.8000
0132.1666
0126.2250
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
uniden ubc125xlt
Moonraker M10
scan125
Call Sign: 26TM8080
Re: Air Band question
Post by scan125 »
The 108 to 137 frequencies are allocated to Civil Air Band. Main Military is 200MHz to 400MHz
https://www.javiation.co.uk/vu.html
You have to remember that military aircraft share the same airspace as civil aircraft so will be often under the control of civilian ATC as well as military ATC. You can liken this to military road transports in the UK. They generally have to follow the roadways, signs, and signals etc. like every other road user.
Nick - Author Of: Scan125 - Scan75 - DriveR8 - http://www.nick-bailey.co.uk
pete_uk
Post by pete_uk »
There are some military allocations in the VHF airband, but if they are in controlled airspace or around a civilian airfield they will use their frequencies just as everyone else.
AMX97
Post by AMX97 »
Ah right fair enough the more you learn... i forgot to add this was over leeds so probably talking to tower and so on.
TYT - MD380
TYT - MD390
Aliunce HD-1
Motorola DP4400e
Motorola DP3601
Baofeng UV-82
Baofeng UV-5R
uniden ubc125xlt
Moonraker M10
Ant
Call Sign: 26TM718
Post by Ant »
Basically with regards to 'air band', each airfield tower has its own frequency, be it military or civilian. So, a military tower will have its own frequency, as does a civilian tower. Once aircraft are out of the control zone of that airfield, they're passed over to a control zone, which controls all traffic, military and civilian, such as London Control.
These control centres are staffed by both military and civilian controllers, for no other reason than that it's good experience for a military controller to control civilian/shared air space along side the best controllers in the business, civil air controllers.
Shack? Shack is a poorly built building in a third world country, which is on the brink of collapse. I'm not calling mine a shack...
Ranger RCI2950DX
Uniden UBC3500XLT
Baofeng UV5RC
Baofeng 888s
