Innovative Antennas
- Call Sign: 29SC01
Innovative Antennas
Hi folks, has anyone here used an antenna made by Innovative Antennas? I came across the name when I read an interview on cbradiomagazines website. I was thinking I might buy one of their OP-DES Yagi's some time next year. I was wondering if anyone on the forum had used any of their antennas, and how they felt about how it performed?
All opinions welcome
Thank-you.
Thank-you.
- Call Sign: Lemmy
- Yamanx
- Call Sign: 26FB001
Re: Innovative Antennas
I have just bought one of these babies
https://www.innovantennas.com/en/our-an ... ovAntennas
Not tried it yet, and I have made some engineering improvements. I have had to buy some scaffolding to install it, so it will be early spring before it is operational. I'll be sure to review it
- Call Sign: 29SC01
That's pretty impressive at just over 9 meters in length.
How high will you be raising it? It looks the biz.
Congrats on your purchase Yamanx. What engineering improvements did you do?
- Call Sign: 29SC01
ch25 I haven't looked about getting a yagi before as I was happy enough with the Sirio Gain master. I'm interested now and being able to import one from Canvey Island in the UK rather than importing one from the USA is more attractive and less bothersome with Customs etc etc. As regards whether or not its a full size yagi, well I don't have a tower to put a full size one on, well not yet anyhow.
- Auldgeek
I've used Justin's antennas for a few years. I can only speak for his vhf & uhf antennas but build quality and performance are excellent.
Currently use his Dual Band 6m/4m 8 element yagi. It's full size on each Band, so no requirement for traps, coils or weird gamma matching arrangements.
Also use one of his Log Periodics for 130-1300Mhz. Again, excellent build and performance.
Both antennas are low noise.
Auldgeek - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
I've changed radios that many times, I've forgotten what I have
- Call Sign: 29SC01
Thanks Auldgeek for your reply. Going by that report about the various antenna for differing band lengths doing what their designed for , then I have to seriously consider purchasing one, when I've got the funds available.
- Yamanx
It will be at about 14 meters high, same as the current one.barefootindian wrote: ↑03 Dec 2019, 23:28That's pretty impressive at just over 9 meters in length.
The plastic insulators were made of a flat piece of perspex about 2 inches wide, this looks crap and is clamped in place poorly. So I'm using some plastic clear tube, also the fixing bolts will be stainless and I resized some of the clamps to fit better.
I'll take loads of pics when I install it
I'm hoping you mean anything you have to buy for the installation will be stainless because if they've supplied non stainless fittings that's really cheapskate given the overall cost and its intended use.
