Antron 99 use washers or not?
Master Virus
Post by Master Virus »
Bought an Antron 99 to get me up and running and i was wondering if the washers were left out would it cause high swr or is this an old wives tale?
I'm also going to waterproof the antenna.
Dave C
Call Sign: 27PL259
Re: Antron 99 use washers or not?
Post by Dave C »
I'm also about to erect an Antron 99 and would like to hear the response on this one too... presumably by not fitting the washers the antenna is being shortened ever so slightly (4-6 mm).
TIA Dave
Life is like a box of chocolates.... Usually empty when I get there.... :crazy:
Rigs: Major M588 AM FM SSB (Std), President Grant II Premium (Std), Midland Alan 78 Plus (Std), Lowe TX 40 (Std).
Twigs: Antron 99 (Std), K40 Mag, Firestick 4', Cherokee Dial A Match 4', Sirio 5000 PL Mag.
Stronty
Post by Stronty »
What is achieved by not installing the them?
Post by The Collector »
They're anti-vibration to stop thecsections coming loose. There was a topic not long ago that went into it quite a bit if you want to search for it.
They're anti-vibration to stop the sections coming loose. There was a topic not long ago that went into it quite a bit if you want to search for it.
NightProwler
Call Sign: 163TM186
Post by NightProwler »
Theres an echo in here :D
Crackle
Post by Crackle »
If they are anything like the Solacon Imax then the washers are rubbish steel that will rust and could cause issues later.
Pardon....pardon...par
I pressed send on the first one, but before it "went" I amended a typo. It must've already gone through but not shown up as having gone as it was still on my phone's screen.
