Hi all i am getting What sounds like Skip On 245Mhz its all day long could it be satellite transmissions? if so anyone k how i could improve reception.I
am using RSD-DUO with diamond v 2000 antenna
Here is youtube i recorded
https://www.youtube.com/watch?v=QaLwT0BVUJw
245Mhz Transmitions What is it?
- Call Sign: mm3vee
- Metradio
- Call Sign: G7HID
Re: 245Mhz Transmitions What is it?
South American illegal radio users - mostly lorry drivers on an open US DOD satellite.. has been going on for a while now..
Mike
Mike
Satcom pirates.
To improve signal you need proper antenna: https://www.thingiverse.com/thing:388651
http://www.blackcatsystems.com/radio/sa ... tenna.html
Proper is good but it's overkill to listen to Satcom. Much easier to knock up a quick NBS yagi, it'll be 3dB down on circular which is nothing to worry about.
- Call Sign: mm3vee
thanks, guys...
Any antennas i can buy cheap instead of building a kit?
- Metradio
- Call Sign: G7HID
Then you will have to learn Spanish ...
Mike
Mike
- Andy
I use a DAB folded dipole from B&Q. It seems to work best horizontally, but there's not a lot in it. The transmissions can pop up almost randomly between about 245 and 256 MHz, so it's worth tuning about. There are some satellite transponder 'stripes' around 244.2 and 249.2 as well, which you should see if you are using an SDR.
'SOMEONE GET ME A SAW!'
Andy.
Andy.
- Andy
Stripes today on 244 MHz.
Andy.
Andy.
- radiosification
I think most of the pirates on satcom speak Portuguese actually. At least in the recordings I've seen
- Metradio
- Call Sign: G7HID
Portuguese - Spanish with a Welsh accent
Mike
Mike
