Adjust signal meter on Omega force s45
- Call Sign: 26SF333
Hi can anyone tell me what I need to do to turn the signal meter down on my Omega force please,I think it's rv101 but not matter where I look I can't find it,is this correct one?if so can anyone please show me where it is on the board?Many thanks.
- 14CS06
Re: Adjust signal meter on Omega force s45
Hello
Please look at this link
http://www.cbtricks.com/radios/rflimite ... in_pcb.pdf
http://www.cbtricks.com/radios/rflimite ... gnment.pdf
Hi what am I looking at?I have downloaded that link but it means nothing to me?I just need pointing at which one I need to alter to turn signal meter down,that's the needle signal meter and the bar graph one if u can show me on the radio that would really help.Thanks
- 14CS06
Sorry I still don’t know which u mean?someone has replaced them and there’s nothing identifying them that’s y I need a photo of where it is with a arrow or a ring around what I need to alter.
- Black Spirit
Ok Nick cheers for that,I will give it a go but am sure I did try it and nothing happened.
Tried that it does nothing still needle at 8 and bar graph at 9.Rest of radios showing max 3,so not a clue?
- Black Spirit
What mode are you trying to adjust as i may be wrong but 101 could be AM/FM and 102 is SSB ?
Hi Nick,I tried in Ssb but it says in the link Claude put in message earlier in this thread that 101 did am fm and Ssb?
- 14CS06
Right Claude many thanks for all yours and Nicks help I will go give it ago now,I will report back soon as.Cheers Mark
Right analogue meter is done,many thanks.Bar graph one hasn't changed is there a way of setting that?I get around a signal floor of between 3 and 5 but bar graph meter is still showing 9?I know there not so accurate.Anyway thanks again,Mark
- astradyne
With the Omegaforce there's no way of adjusting the LCD signal meter. It's completely independent of the analog meter and has no VR to set its level. The Deltaforce has the same issue.
Placing a resistor/VR inline to the LCD meter would be the way forward (a VR would allow you to fine tune to your requirements). However this method would also affect the modulation meter when in TX.
Ok Andy cheers for that,hope your all ok?Be good to see u when u have time.Mark
