how to quieten the background noise ICOM IC-706 MK11G
- WARLOCK
- Call Sign: 26TM134
Is there any way or the best way to cut down on the background noise on my Icom 706 MK11G , I think there is a way ??? i am not very good with menv radios, George
- Buick Mackane
Re: how to quieten the background noise ICOM IC-706 MK11G
Iv'e never owned a 706. But i presume like most modern HF radios it will have a switchable preamp, If its set to on turn it off, Preamps aren't needed on HF
As Buick Makane has said, on HF, you can switch the pre-amp off and on 40 and 80 metres you can go further.
The pre-amp button cycles through "pre-amp on", "pre-amp off" and "attenuator on"
Another one (not cheap but very effective) is fit the FL223 narrow ssb filter.
If you also dabble on CW or RTTY, there is a second socket so you could fit a cw filter as well
If you listen on the cw end of an active band without a cw filter, you will find 3 or 4 signals in the passband
I'm not keen on the dsp noise reduction on the 706 as it puts "watery artefacts" on the signal
Other than that, I think it's a damn good radio
What antennas are you using,and how are they earthed Warlock ?
27.555 Usb
27.555 Usb
- WARLOCK
At the present time i am using a sirio gainmaster which i do not have earthed , Iam going to put a doublet antenna up on a fibreglass 12mt spiderpole as soon as the weather gets better will i have to earth that antenna if so how ?? George
- RadioPixie
- Call Sign: 26TM552
There's also the DSP "NR" function on the 706 that will reduce the background noise somewhat.
