Superstar 360FM PB010-AA Beep.
superstar
Re: What CB/11m Radio Stuff did you buy today? (2018)
Post by superstar » 12 Jan 2020, 18:34
bought this 148 mk2 locally, beep disabled,( what do i look for to enable the beep?) uk 40 on ch9 switch and alphas on the tone switch, apparently its been languishing in a shed for years ( i’ve cleaned it up a bit) it came with a ham 4200 base mic which the battery was dated 95, so possibly last used around that time, seems to work reasonably well
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
slamjam
Call Sign: 26DT871
Post by slamjam » 13 Jan 2020, 07:34
superstar wrote:
12 Jan 2020, 18:34
If it's a mk2 the orange wire which goes to the hole on the pcb marked "Peep", near the mic socket has probably been cut or removed. Should be easy to reinstate.
26DT871 - Ipswich UK
superstar
Post by superstar » 13 Jan 2020, 08:27
slamjam wrote:
13 Jan 2020, 07:34
superstar wrote:
12 Jan 2020, 18:34
cool thanks i’ll av a look
Cb handle
superstar
Post by superstar » 13 Jan 2020, 17:40
had a look and cant see anything marked peep near the mic socket, heres a pic of the board, some loon has added positive and negative sockets to the rear
Cb handle
slamjam
Call Sign: 26DT871
Post by slamjam » 13 Jan 2020, 20:10
Should be here: Orange wire going to the pcb labled Peep
astradyne
Moderator
Moderator
Post by astradyne » 13 Jan 2020, 23:10
The RF meter presets appear to be set way too high. Also the driver bias preset is cranked up full. The connectors on the back are pointless. It may be worth your while sending it off to Nick for a clean up and service.
superstar
Post by superstar » 14 Jan 2020, 08:01
thanks for the pics Slamjam, looks like mines a different board, it ends with AA and not AB, there’s no beep marked on board, and yes astradyne i think i’ll send it Nicks way and get all this junk out of it and put back to standard, here’s a pic of the board number too, what does it make this then an early mk2 or is it a mk1?
Cb handle
astradyne
Moderator
Moderator
Post by astradyne » 14 Jan 2020, 08:30
superstar wrote:
14 Jan 2020, 08:01
Being a PB-010AA board makes it a very early MK2. The PCB has a slightly different layout to the PB-010AB.
13EL121
Call Sign: 13DA121
Post by 13EL121 » 16 Jan 2020, 18:23
superstar wrote:
14 Jan 2020, 08:01
The Peep wire should be the orange wire marked in the photo. But this is off topic. Should be moved to repair forum.
