Any interest in Philips FM1100/FM1000 radios?
G4FAW
Call Sign: G4FAW
Re: Any interest in Philips FM1100/FM1000 radios?
Post by G4FAW »
Hi Steve, did you get the software up and running and is it available? I have aan original CDP and PDP but yours looks easier to use... I have a programmer. Thanks Dave
G4FAW
Call Sign: G4FAW
Post by G4FAW »
I have downloaded the software from Github and it appears to work ok, but I have a USB CH341A programmer and it doesn't seem to interface with that, has anybody done this?
RojOBC
Call Sign: G7OBC
Post by RojOBC »
Hi All
Some very interesting reading on this board .....
I think the FM1100 is well worth the effort to get on the VHF and UHF bands .....
My stock at the moment is:
3 off FM1100 UHF VTM12. On 70cms with 99 channels
1 off FM1100 VHF SA911. on 2mtrs with 88 channels
1 off FM1200 E0 band . without any programming - still thinks its a trunked radio (either electricity board or railway type)
Do you know if there are any of the PA1DEN chip sets available to buy to convert to 4 mtrs ??
I also have a PDP on loan, but no documentation. I have been trying to set up CCTS and a scan, but I think I am doing something wrong !
So far... all channel frequency's are set, starts up on calling channel and I have a Squelch defeat button, so far fo good
Sensitivity and audio are fine, looking for a slide in tray with power and antenna connector.
Cheers chaps, keep up the good work !
Roj
26mb04
Call Sign: 26MB04
Post by 26mb04 »
It should be possible to clone the PA4DEN chip or whatever it is. It'll be an eprom or similar, I'd have thought.
Sent from my GP300 using DTMF
RojOBC
Call Sign: G7OBC
Post by RojOBC »
Hi
I think there are 3 chips involved, 2 in the radio and another in the display
Is it still possible to buy the complete kit from PA4DEN ??
Just powered up the Low Band FM1200, all working but it cannot find its trunking master signal so does nothing .....
I have attached a file which gives the PDP commands for the FM1100, may be useful ....
Roj
G7OBC. IO92BN
RojOBC
Call Sign: G7OBC
Using the PDP
Post by RojOBC »
I am using the PDP ... trying to program buttons 7 & 8 ...
After setting the parameters (501 to 508) with the PDP connected, buttons 7 & 8 shift the channel up and down, all OK.
But when I send out from PDP to Radio and remove plug to power down .... then switch on, the buttons do not function.
Am I doing something silly ? Is there another parameter to set or do I have an eprom problem ??
I hope someone can help.
TIA
Roj
