Anyone know where I can get a real short power lead for this YAESU FT-857D no more than 1' 5"?
This flipping thing that came with the radio is far, far to long at about blooming 3 meters.
I don't really want to chop this down just in case I do ever use it mobile but if I have to then I will chop it up.
Short power lead for a FT-857D
- nay27uk
M6LIG / 2E0LIG / 26TM1995
Baofeng UV5R+
Boafeng RD-5R
YAESU FT-857D - Watson W50 - HF-SE-360
Malahit SDR - Ground Loop
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- Auldgeek
- Call Sign: GM0BRJ
Re: Short power lead for a FT-857D
There's a few on eBay. Genuine ones will set you back £20-£25 but one or two oem ones are advertised.
http://www.ebay.co.uk/itm/Yaesu-Kenwood ... SwuxFY3NXK
Just cut this one back to suit. You would need to add fuse holders though!
Or this one with fuse holders. Still a saving
http://www.ebay.co.uk/itm/ICOM-YAESU-KE ... SwLVZV6Lha
The problem you will have is that most of these, if not all, have the fuse holders at the power supply end so whatever you do, you will need to chop and add/modify the fuse holders.
Auldgeek - Drew
- nay27uk
Thanks pal chopped it already using the same fuses though.
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
