Which datacable Lincoln 2+
ballo
Call Sign: 19DD03
Post by ballo » 03 May 2017, 18:50
Hello,
I bought a President Lincoln 2+ and this transceiver has a data-port onn the backside.(see photo)
Is a special data-cable (with interface) or is a normal mini-usb cable needed to prgram the L2+ ?
http://www.pa3hgt.nl
President Veep 40 ch am/fm,President Adams with Ir. Maurer mod,President Jackson Classic,Sommerkamp TS788 caffeewarmer with Ir Maurer mod,Ranger RCI-2995,Dirland DSS9000F,President Lincoln 2+,RM HLA 300V+ with Sirio Turbo 5000.
Otter
Call Sign: 26TM439
Re: Which datacable Lincoln 2+
Post by Otter » 03 May 2017, 19:45
I don't know for sure, but I would guess it's the same as the CRE8900. <link>
Do you know whether the Lincoln 2 V3 has programming software?
Gorgon Brown - a man with all the joie de vivre of a haunted cave in Poland. S1 E3
recoil
Call Sign: 2e0myn
Post by recoil » 03 May 2017, 19:50
I use the same lead as the alnico 135/cre8900 crt 9900
Auldgeek
Post by Auldgeek » 03 May 2017, 20:15
recoil wrote:I use the same lead as the alnico 135/cre8900 crt 9900
+1 :thumbup:
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
Thank you NHS :clap:
ballo
Call Sign: 19DD03
Post by ballo » 04 May 2017, 04:50
Otter wrote:I don't know for sure, but I would guess it's the same as the CRE8900. <link>
Hi otter,
Did you look on this page : https://simonthewizard.com/11m-live/
@all: thx for replies ! I have a cable for the SS9900 ;-)
Otter
Call Sign: 26TM439
Post by Otter » 04 May 2017, 17:42
I wasn't aware of that page, but there's nothing there.
simonthewizard
Post by simonthewizard » 05 May 2017, 15:16
Otter wrote:I wasn't aware of that page, but there's nothing there.
Software sits there: http://tinyurl.com/kn4q5wh
But just really memory stuff and change band names
Otter
Call Sign: 26TM439
Post by Otter » 06 May 2017, 17:59
Thanks Simon, but for some reason that page won't load for me.
simonthewizard
Post by simonthewizard » 07 May 2017, 13:39
Otter wrote:Thanks Simon, but for some reason that page won't load for me.
Works here, so try:
http://tinyurl.com/mnd9mpd
Direct from Server
Funker
Post by Funker » 13 May 2017, 12:17
Hello
I bought a 6 in 1 cable for $7 one year ago.
It fits for different brands like Yaesu, Icom, Retevis, Anytone, Kenwood and so on. Six adapters and a CD rom are supplied. One for all the ssb exports is missing.
Yesterday I made my own adapter for the lincoln II+ with an old mini-USB cable and a 3,5mm stereo jack. I connect it to the main USB converter of the 6in1 set.
Works perfekt! If you need pinout or pics give me a message!
73s
Domand 61
Call Sign: KC3GGS
Post by Domand 61 » 18 May 2017, 21:09
i just purchased a Lincoln 2+3 it has no white wire inside. How do you convert it for extra frequencies?
recoil
Call Sign: 2e0myn
Post by recoil » 19 May 2017, 11:43
have a look at this for export mode http://delboyonline.blogspot.co.uk/2017 ... t-mod.html
Domand 61
Call Sign: KC3GGS
Post by Domand 61 » 20 May 2017, 22:45
My display doesn't show what mode the radio is in. How do we fix this? Thanks {bnghd}
CameraMan
Post by CameraMan » 07 Mar 2020, 13:39
Funker wrote:
13 May 2017, 12:17
Hello
73s
- That sounds great! I`ll be happy if you provide me pinout for your solution.
What I am really looking for, is a pinout for an ordinary Mini-usb cable to use for programming the Lincoln II+,
maybe it is possible to cut the cable and reconnect the wires to fit this radio?
73s \CameraMan
Otter
Call Sign: 26TM439
Post by Otter » 25 Mar 2020, 10:46
CameraMan wrote:
07 Mar 2020, 13:39
73s \CameraMan
Certainly with the SS9900, CRE8900 and Anytone 5555 type radios - they use +5V RS232 on a USB connector, not USB.
If this is the case with the Lincoln 2, which I suspect it is, you won't be able to use a standard USB lead.
