UHF Fire
- Metradio
- Call Sign: G7HID
Re: UHF Fire
457.0125 FIREFIGHTER FIREGROUND RADIOS FA1
457.0375 FIREFIGHTER FIREGROUND RADIOS FA2
457.0875 FIREFIGHTER FIREGROUND RADIOS FA3
457.1375 FIREFIGHTER FIREGROUND RADIOS FA4
457.1375 462.6375 FIREGROUND DUPLEX CHANNEL 5
457.1875 FIREFIGHTER FIREGROUND RADIOS FA5
457.2375 FIREFIGHTER FIREGROUND RADIOS FA6
457.4875 FIREFIGHTER FIREGROUND RADIOS FA7
Mike
Mike
Re: UHF Fire
Do you actually receive any traffic on these channels these days?
- Mikel
Re: UHF Fire
I can confirm that 457.0375 is very busy around here (South East Wales).
Re: UHF Fire
Scotland fire and rescue use them and still analogue, some areas use these frequencies on digital now.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
- Minus1
Re: UHF Fire
This is what I have:
:1 457.0375 General Incident Ground
:2 457.0875 / 462.5875 (Mobile repeaters)
Some fixed sites e.g Birmingham Airport, Bham Airport Fire Service refer to this as 'local authority channel')
[NB 462.5875 is US GMRS:2 which causes problems occasionally]
:3 457.0125
:4 457.1875 (RAF fire are reported to have this channel too, unconfirmed)
:5 457.1375 / 462.6375 (Mobile repeater)
[NB 462.6375 is US GMRS:4 which causes problems occasionally]
(Leics occasional use this as a repeater for fire control - presumably relayed thru Airwave on the appliance)
:6 457.2375 Water relay?
:7 455.9875
:8 455.9875 / 462.5375 (Control vehicle repeater - same freq as 7 simplex)
:9 457.4875 BA team?
:3 457.0125
:7 455.9875
- thelad
Re: UHF Fire
457.1875 has never been used by the RAF AFR anywhere iv been.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- welshevo
- Call Sign: 163TM995
Re: UHF Fire
Mikel... i thought South wales fire were now using DMR? and where abouts are you ? as ive had that programmed into my handie and never heard anything in cardiff? ....inbox me?
Tetra is a Lonely place! Get DMR instead! (163TM995) ......
- Mikel
Re: UHF Fire
Sorry, I should have been more specific ha ha, and not just stated south east Wales, bit lazy on my part. I am spending most of my time at present just outside Caerphilly and 457.0375 FM is used daily.welshevo wrote:Mikel... i thought South wales fire were now using DMR? and where abouts are you ? as ive had that programmed into my handie and never heard anything in cardiff? ....inbox me?
The way it seems to work is that they will arrive at an incident and someone with a radio will assess the scene and call back to the appliance instructing what type of 'stop' message to send to control with the Tetra radio.
Also heard them using it locally whilst checking smoke detectors and for giving instructions as to what ingredients to purchase in Asda so that a curry could be made back at the station.
I was under the impression that it was all 'South Wales Fire and Rescue Service' these days but maybe not if Cardiff is using DMR for Fireground comms?
- thelad
Re: UHF Fire
Most areas can switch to DMR now when working with other areas that use DMR all the time.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- Mikel
Re: UHF Fire
How do you know this?thelad wrote:Most areas can switch to DMR now when working with other areas that use DMR all the time.
- Metradio
- Call Sign: G7HID
Re: UHF Fire
They would need DMR capable radios to do thet..
Mike
Mike
- LeakyFeeder
Re: UHF Fire
At a recent big fire in Barnsley the numerous ground units on handsets were using 457.0875 simplex...
- radiosification
Re: UHF Fire
I would assume that actually any areas with DMR radios would be using DMR, and then would switch back to analogue if they were working with another unit that has only analogue radios.thelad wrote:Most areas can switch to DMR now when working with other areas that use DMR all the time.
