Grant PC 999-AC No receive
Re: Grant PC 999-AC No receive
Remove the shorting board from TP 7, 8 and 9, see if the receive comes back on SSB.
- astrolab
- Call Sign: F0GIQ
Good morning Zephyr,
Thank you for your interest for my problem.
Removing shorting board no change the receive on SSB.
BUT, bad solder under TR 19 , now it's OK
Many thanks
Best 73/51
Michel
Many thanks
Best 73/51
Michel
CB's collector-IC 706 MK II-FTM 350 R/E Ant X300-FD3-Black Pirate....
That's a good result, now enjoy using your Grant.
- Mudslinger
Glad you got it sorted.
The PC-999 Grant is probably my favorite Multimode set.
- astrolab
- Call Sign: F0GIQ
@Mudslinger;
And mine also, i have fifteen "GRANT", all models since 1975.
Best 73/51
Michel
Best 73/51
Michel
- Mudslinger
I have had three of them, and would certainly have another.
A better radio than the Cobra 148/SS360 In my opinion, the only thing they lack is a decent KC shift.
Both mine have the MC145106 PLL fitted with a PIC and zero switching with 5 bands and I only need about 3KC's total shift to get everything I need.
I've had loads of 148's and 360FM radios but I would rather have the Grant 999 any day even over a Jackson, they have too much shift for me.
Oh and both have the 3900 counter fitted to them and switchable tone on the receive.
- George EI7KO
- Call Sign: EI7KO
Any progress on the DZ-999 since Dave? I'm well underway on mine now, Almost all the fabrication work is now complete and ready to start on the electronics....Just if I had more time......sigh
BLUE LED'S ARE BEST!!!!
- Coppernob
I have the silver fronted Grant modded with five bands
10 kHz switch on the mod button ,the brite switch does nowt.
The clarifier has been unlocked and does about 6khz up and 3-4 kHz down so to get the zeros I go a channel down and slide up.
It is my mainstay radio that I use all the time.
Fantastic receiver ,but does tailor off a little on the low channels of super low.
I wouldn't be without mine,fantastic audio reports too,perhaps a bit to much as a power mic ain't needed and over drives dramatically ,so I use the standard coffin mic.
One gripe is too much power output for my linear...
There is a variable power pot fitted to the rear that works on am/fm only.
All in all a brilliant buy off a fellow forum member.
I gotta a decal off Simon (cheers mate) and I'm going to pimp it in a nice electric blue colour when I get round to it.
Is the other Grant just as good ...the one with the fine/coarse control.
I like it as much as my mint mk2 cobra 148.
A classic radio IMHO .
Regards Coppernob Roger.
- Mudslinger
The Grant with the Dual clarifier works just the same, the only thing is the dual clarifier is a bit pointless as standard as it doesn't slide much.
I shouldn't really have sold my black one. It worked well, but was a bit worn.
I replaced it with a Mint Mk2 360FM, but like I said it doesn't seem to perform quite as well.
George,
I'm still waiting for the engraver to finish the front, the last time I called in he had done the GRANT 999 DZ but that was all.
I think maybe I should have bitten the bullet and shelled out the £100 to have it done by the chap that did the last one for me but I re-anodised the knobs and the handle brackets today and they look great.
- George EI7KO
- Call Sign: EI7KO
Good stuff Dave. I'll look forward to seeing that.
ive seen it working in production and heard it , its a monster and looks excellent , lot of work gone into it , zephyr deserves more than he gets for them , hes probably workin for a quid an hr but knocking out great radios that will be better remembered that the jentecs and others .keep it up dz and i want a grant next . although i love the 360 with zero switching the band indicator LEDs have got me hooked, havnt turned the 3900eft on or the marantz 360 since i got this one. aiwa 1979 amp fitted with dz 360 working the world.
- Anthony123
- Call Sign: Gw0
Do you have audio, I mean Hiss from the speaker on SSB but just no RX or no signal and no Audio..Have you hooked up a sig-gen or another radio to use as a sig-gen to see if there is any Recive at all.. ?
As you say its only SSB receive thats gone down.. then i would assume that when you turn the volume up fully you should have some audio ( Hiss ) .... Could you elaborate a bit more... Thanks
- George EI7KO
- Call Sign: EI7KO
Cool. Pictures please. I'm nailing something very special together myself....
