Preventing unauthorized use of my radios
- Call Sign: geek1
So just wondering with one of the mock questions it was along the lines of "how do i prevent unauthorized use of my radio equipment". Do i need to really do this if its at home or do i go for the one socket that is connected to one them emergency stop switches with a key to release the switch. (Sorry i just think it be cool to have it labelled as press in the event of lack of strongbow). I am half feeling the latte but i just wanted to see if others do it and how they do it.
Presently own:
2X Dipoles (2M / 70CM)
2X Baofeng UV-5R (UHF/VHF)
2X puxing PX-777 (UHF)
1X Puxing PX-328 (VHF)
4X Corba MT600 (PMR)
2X Baofeng 777s (UHF)
1X Icom F510 (VHF 2M)
1X Diamond RH771
Oh and a 10ft Pole
1X Diamond RH771
Oh and a 10ft Pole
- Banned
- Call Sign: jon
Re: Preventing unauthorized use of my radios
My understanding is that if someone without a license (other than member of user services) wishes to use your station, you say no..... You don't need padlocks or the like.
You can't supervise unlicensed people on foundation conditions either
Edit, you do have the 'foundation now' book yes?
- Call Sign: geek1
I have got my foundation book already and on some the mock exams getting 18 out of 26 which is not to bad as it thinks it should be a pass. Just where i been ill i not looked at the book Dam the common cold. I got my exam on 23rd. It's more i know at home im ok but if i leave a handheld at my other half i got to remove the battery, put it in a safe, followed by a second safe, big alarm, guards, more guards just to stop it being used. Oh little sisters never make things easy.
Presently own:
1X Diamond RH771
Oh and a 10ft Pole
1X Diamond RH771
Oh and a 10ft Pole
- Call Sign: 2e0dxi
18 out of 26 is ok have you been using hamtests to do the mocks as its a good site.
And once you go and take your course that score will go up a lot only thing that was a problem was morse apreciation as i couldnt process the dits and dots due to my problems but i even passed it.
And no making radio safe is just make sure no-one uses your radio maybe just remove the mics when you are not there or disconnect the radios and put them in your pants draw .
or failing that a bengal tiger or landmine in your room would also do
Kenwood ts2000e heil studio mic
altron 12m mast tailtwister rotor
hygain th3 mk3 triband/cushcraft 3 ele 6m/2x9 element 2m
gainmaster/x510 whitestick
jaybeam airband vertical
- Ashtec
- Call Sign: M6LTD
Most of it the answers are within the questions my lad went for his test and he knows note at all bout radio and he only failed buy a few mate
- Call Sign: geek1
i was using hamtests and at times i found some times you get 4 answers and no questions. what normally catches me is when a question has 4 answers with very little in them. The call sign questions i know i got to look at as if i get a different part of the uk one i am having issues.
Presently own:
1X Diamond RH771
Oh and a 10ft Pole
1X Diamond RH771
Oh and a 10ft Pole
- RadioNerdz
- Call Sign: 2E0
This'll either boost your confidence or make you feel terrible...
http://www.southgatearc.org/news/april2 ... n_exam.htm
You'll be fine! I managed it when I was 13 - dropped two marks, both were quite ambiguous, with more than one correct answer, just wasn't what the examiner wanted.
I wasn't aware of these online tests.
Good luck!
RN
Good luck!
RN
- Call Sign: geek1
Been busy so not had a time to reply, i am doing better as my other half has just got me a icom f510 on VHF. Lucky the radios going to be living in a secure store as they be with all the handhelds and my production equipment.
Presently own:
1X Diamond RH771
Oh and a 10ft Pole
1X Diamond RH771
Oh and a 10ft Pole
- archspoofer
Does the Icom FC-510 have variable power output ?geekyninja wrote:Been busy so not had a time to reply, i am doing better as my other half has just got me a icom f510 on VHF. Lucky the radios going to be living in a secure store as they be with all the handhelds and my production equipment.
Age and knowledge don't always come together. Sometimes you just get the age...
- Call Sign: geek1
I asked the seller and he said it did, as i have the programming software and it does Low1 Low2 High.
Presently own:
1X Diamond RH771
Oh and a 10ft Pole
1X Diamond RH771
Oh and a 10ft Pole
- archspoofer
geekyninja wrote:I asked the seller and he said it did, as i have the programming software and it does Low1 Low2 High.
That's kewl. I had looked at them before but never managed to find out what power options it had so decided not to, Cheers for that :-)
Dan
- Farty
Lock tear door when you're not around.
- Ashtec
- Call Sign: M6LTD
- RadioNerdz
- Call Sign: 2E0
The IC-F510 can be password protected, I'd suggest using that if you're worried.
