152.5875mhz
Scanning radio frequencies in Yorkshire & Lincolnshire
AlfieDivine1
Call Sign: 26CT2369
Re: 152.5875mhz
Post by AlfieDivine1 »
Ok mate thank you for your help!
i am in Folkestone, on the edge of the UK how far does DMR signal reach then Cambridgeshire is long way ! ty
Metradio
Call Sign: G7HID
Re: 152.5875mhz
Post by Metradio »
I would suspect that since Cambs Search and Rescue are using this frequency at a number of sites that other similar organisations might also be using this frequency..
DMR has the same range as NFM - but has Go Fast Stripes on it :)
Mike
AlfieDivine1
Call Sign: 26CT2369
Re: 152.5875mhz
ok thanks mate
AlfieDivine1
Call Sign: 26CT2369
Re: 152.5875mhz
Update ~ Kent Search and Rescue is a member unit of the Association of Lowland Search and Rescue (Lowland Rescue) ... it must be KSAR :)
mrpurrfect69
Re: 152.5875mhz
Post by mrpurrfect69 »
Leeds or Wakefield RAYNET can not remember which one of them it is use/have a repeater setup In the old police VHF band not far from that particular frequency only active tho when operating events that they are involved in
