http://www.fia.com/en-GB/mediacentre/pr ... um=twitter
Map's a bit rubbish but you can get the basic route.
JFMG and Short Term Hire freqs worth checking. Some transmitters may be set up a day or so before actual use.
Wales Rally GB 9–13 Nov
- Minus1
- Minus1
Re: Wales Rally GB 9–13 Nov
163.25 DCS274 Stage times. Must be a high power repeater — I can pick it up near Birmingham!
- fez
are you getting any comms now?
- Minus1
They're occasional transmissions, not continuous, also seem to be some data/selcall bursts.
- Minus1
Digging around the WTR, I've found all these JFMG (PMSE) allocations around Wales, that might be relevant:
162.33750 NFM JFMG NW of Machynlleth / SW of Devil's Bridge / 10km east of Borth ^SH717027 / ^SN709700 / ^SN723907 157.7275
163.03750 NFM JFMG NW of Machynlleth / SW of Devil's Bridge / 10km east of Borth ^SH717027 / ^SN709700 / ^SN723907 158.7375
163.03750 NFM JFMG near Llanwrst / south of Machynlleth / SE Builth Wells ^SH859633 / ^SN728969 / ^SO065447 158.7375
163.06250 NFM JFMG near Llanwrst / south of Machynlleth / SE Builth Wells ^SH859633 / ^SN728969 / ^SO065447 158.7625
163.10000 NFM JFMG Machynlleth / Llansannan / Builth Wells ^SN703998 / ^SH929659 / ^SO043508 158.6
163.25000 NFM JFMG near Llanwrst / south of Machynlleth / SE Builth Wells ^SH859633 / ^SN728969 / ^SO065447 158.75
163.35000 NFM JFMG near Llanwrst / south of Machynlleth / SE Builth Wells ^SH859633 / ^SN728969 / ^SO065447 158.85
163.42500 NFM JFMG Machynlleth / Llansannan / Builth Wells ^SN703998 / ^SH929659 / ^SO043508 158.925
163.50000 NFM JFMG Machynlleth / Llansannan / Builth Wells ^SN703998 / ^SH929659 / ^SO043508 159
163.72500 NFM JFMG Machynlleth / Llansannan / Builth Wells ^SN703998 / ^SH929659 / ^SO043508 159.225
163.87500 NFM JFMG Machynlleth / Llansannan / Builth Wells ^SN703998 / ^SH929659 / ^SO043508 159.375
163.91250 NFM JFMG near Llanwrst / south of Machynlleth / SE Builth Wells ^SH859633 / ^SN728969 / ^SO065447 159.4125
163.97500 NFM JFMG Machynlleth / Llansannan / Builth Wells ^SN703998 / ^SH929659 / ^SO043508 159.475
163.97500 NFM JFMG near Llanwrst / south of Machynlleth / SE Builth Wells ^SH859633 / ^SN728969 / ^SO065447 159.475
164.10000 NFM JFMG Machynlleth / Llansannan / Builth Wells ^SN703998 / ^SH929659 / ^SO043508 159.6
164.10000 NFM JFMG near Llanwrst / south of Machynlleth / SE Builth Wells ^SH859633 / ^SN728969 / ^SO065447 159.6
164.91250 NFM JFMG Machynlleth / Llansannan / Builth Wells ^SN703998 / ^SH929659 / ^SO043508 160.4125
167.52500 NFM JFMG Machynlleth / Llansannan / Builth Wells ^SN703998 / ^SH929659 / ^SO043508 172.325
This is clearly a co-ordinated network as some frequencies are re-used in 3 or more locations. Some freqs are listed twice cos they seem to fit into 2 nets.
Some of the locations are very remote, I can only think of the rally that would need such a number of channels in such a location.
Some of the grid references are a bit suspect, one is in the middle of a bog, yet 500m away is a hill top; another seems to be 300m from a marked transmitter. Perhaps they are only approximate or nominal locations.
(The Builth Wells allocation might also be used for the Royal Welsh Show.)
