SUPERSTAR 3900 DIRLAND BLACK bands???
Avenger
Call Sign: 163TM122
Re: SUPERSTAR 3900 DIRLAND BLACK bands???
Post by Avenger »
My 3900 black has got an extra switch inside fitted to a bracket that when flicked stops all the other bands working and makes it 40ch mid only. A bit odd as it looks factory fitted.
163TM122 - ROB
Post by Admiral »
Avenger wrote:My 3900 black has got an extra switch inside fitted to a bracket that when flicked stops all the other bands working and makes it 40ch mid only. A bit odd as it looks factory fitted.
They were done like that so that they could be legally imported and VAT paid on them, then converted back to an export radio easily, same way modern ones need a diode lifting, or a wire cutting, or a blob of solder adding etc.
Mudslinger
Post by Mudslinger »
Admiral is correct, they are factory.
Strangely though not all of them had the switch. I think it depends where they were originally sold.
astradyne
Moderator
Moderator
Post by astradyne »
And, of course, the later CRT 3900's had the pull out SWR CAL knob to open it up from 40 channel CEPT to export mode. Good idea as you didn't have to break the seals and invalidate the shop warranty after you got it home to find it was mid band only. Looked daft though with the control sticking out.
Avenger
Call Sign: 163TM122
Post by Avenger »
I had it from Belgium, there is a pull out knob on the swr/cal which is marked as DFB or something similar.
163TM122 - ROB
Mudslinger
The DFB has to be the most pointless feature ever.
14CS06
Post by 14CS06 »
Hello
Yes extra switch inside factory fitted
Avenger
Call Sign: 163TM122
Post by Avenger »
Yes that's the setup Claude but I think mine only has one of the add on boards fitted.
163TM122 - ROB
cb4ever104
Post by cb4ever104 »
Avenger wrote:Yes that's the setup Claude but I think mine only has one of the add on boards fitted.
There's a few different add on boards depending on the model of the radio . DBF filter , echo board , PA board etc. The main EPT36XXXX pcb is more or less the same for them all .
