Mitex Programming Software
- New User
Re: Mitex Programming Software
I still cant get the software to read the Sport (VHF) radio
I have tried both a serial lead and a usb lead and have clicked on the connection twice.
- donga
- Call Sign: M6RKA
Guys i have the Mitex and the Wouxun. I have the software and lead. It works on my computer.
I have got channel 1-3 working but when it comes to 4 onwards i dont know how to save the next codes as it seems to overwrite the first 3.
How do i use the wouxun software to sort this out.
I know im doing something wrong.
hi guys
I dont know if any of you guys have a bit play with these mitex, but have you looked at the freqency that these can go to
Field1=134-175MHZ|350-390MHZ|395-475MHZ|395-425MHZ|445-475MHZ|100-510MHZ
maybe room to play around with,,
sorry I cant play as I dont have any mitex to play with
but the soft ware seems to look like the wouxun just with the 16 channels instead of the 128 ,,
Binatone 950
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
QuanSheng TG-UV2
TYT 380 + TYT 9600
Kirisun S780
HYTERA PD505
WHISTLER TRX2
mi0mso wrote:I still cant get the software to read the Sport (VHF) radio
i noticed these radios in maplin tonite when i was in there, they look nice, make sure you have the software set up for the vhf band, and make sure you have selected the correct com port.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Has anyone found a way of reprogramming the Mitex Sport (VHF) radio yet please....I've tried using a kenwood cable, and the SFE820 software. When I try to read from the radio, it says "Because the type of radio does not match, communications is interrupt" <sic>
I could really do with changing some of the tones on this radio.
TIA, Jim
TIA, Jim
- Call Sign: gy32
do anyone know where can get software for mitexs and i have h777 cable wood that work with mitexs as it a kenwood fitting can anyone help!
- Call Sign: victor
Hello,looking20uk wrote:do anyone know where can get software for mitexs and i have h777 cable wood that work with mitexs as it a kenwood fitting can anyone help!
Which Mitex handset do you have? They use their own specific software.
Victor.
- Call Sign: victor
Thought others may be interested to see, apologies if this is old news.
Victor.
Edit: Just noticed channel 16 says it is the same as channel 15 - not sure why. channel 16 is infact blank for scanning.
Hi There
I know this is a old thread but any chance that someone can help me with a copy of the programming software for the Mitex Sport (SFE S820 vhf) ?
Regards
Sean [email protected]
South Africa
Regards
South Africa
Mitex Sport VHF programming
software is the SFE S-580 software
https://hamfiles.co.uk/index.php?page=d ... munication
hardware: I used a generic Baofeng UV-5R programming lead.
Appreciate it is an old post but I couldn't find an up-to-date answer, and got this setup working today.
- MrWeetabix
- Admin
- Call Sign: 26TM175
Thanks for sharing matie, really appreciatedscotscanner wrote: ↑19 Mar 2021, 15:37 Mitex Sport VHF programming
Has anyone got a copy of there General DMR series? Interesting to see what colour codes and default talkgroups.
sorry i forgot to ask,
Do the Mitex alllow you to program anywhere between say UHF 440-470Mhz? Or they just stuck to 449MHz?
Edit:
TYT UVF1, Baofeng BF-888s, Binatone Terrain 550, Alan HP450, ICOM IC-R5 with MRW-210, Grecom PSR-282
A bit off topic, and a long shot, but does anyone know the part number for the Mitex VHF Sport RF final?
