I've installed a Sirio Thunder 27 on my balcony and it's giving me grief.
It's sold as a self contained 1/4 wave dipole so doesn't need a ground plane. I've cut my coax to the exact length specified (8.48M) and terminated it correctly. I've also checked continuity of center pin to center pin and of shield to shield and all is fine. I've also checked insulation resistance and all is also fine.
When connected up to the radio and just leant up against my coffee table, I get good SWR, but as soon as I mount it on my balcony guard rail, SWR goes right into the red.
If I ground the aerial to my balcony guard rail, the SWR comes down to 1.5 but I get loads of noise (over 9 on the signal meter) on every channel.
As it's a dipole, I didn't think it should need grounding as it already has one
My balcony guard rail runs the whole length of the building on my floor (probably 80M) and may well be earthed to every floor of the building. Could the ground plane be too big?
Could the noise be interference from electrical appliances inducting from everones flats?
Is there a way to suppress this?
The aerial seems to be working well, apart from the noise, and have heard stations from all over europe calling, but they are fighting over the ammount of backgroud static being picked up.
Any Ideas?
Cheers.
