eQSO / EchoLink-type link for TM net?
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: eQSO / EchoLink-type link for TM net?
Right then....
Fez has completed his planning and we have ordered the parts. We hope to have some basic PTT/serial interface kits ready to go in the next few weeks.
Fez is sending me some kits this week and I will construct one and connect it to a radio here, at which time we will conduct live on-air tests using FRN...
If anyone else is interested in getting an FRN node up and running, please post your interest here. We can provide you with a kit at-cost. We estimate somewhere around £5.
Would be cool to get a TM1 FRN net going on some kind of regular basis!
Big-up to Fez for all his hard work thus far. Its really appreciated matie!
- MrWeetabix
- Admin
There were some interested parties in this....anyone still interested?
I'd be interested, but I also need a rig that can cover 27.500 so I can play.... Any suggestions on something cheap I could use.
- dcwuk
Yes, still interested here
- MrWeetabix
- Admin
This project would be for either UK40 or MID band, whichever suited you best.Red Fox wrote:I'd be interested, but I also need a rig that can cover 27.500 so I can play.... Any suggestions on something cheap I could use.
The kit Fez has designed also means it is possible to connect to a 446 radio and use that as the local FRN gateway....
Look on ebay for older 120ch radios for 27.500 access matie. You'll need one that does a 5kc shift though, as most chanelised radios don't do this...
Thanks,
I have an old Alan 95 Plus, that I converted to 200ch and sure enough the nearest I could get was 5khz out. I got a Thunder pole to try, so just need a BNC to PL259 adapter and I'm ready to go..... Please pm me where the dosh needs to be sent for the kit.
- MrWeetabix
- Admin
Right then, I have my end of the link setup and ready to test tonight, so I'll post details here when we are up and running and maybe a few of us can have a chat :-)
OK, I'll monitor whatever channel you go for on my HF receiver and see what I can hear, its all set to handle PSK31 now.
I assume for PSK31 to be properly utilized it should be on an AM channel so multiple conversations can be ongoing on a single channel ???
- MrWeetabix
- Admin
We have a link up and running!!!!
Local node is now active on Tyneside, ch31 UK40 (Muppets)
Not on the main antenna, but anyone within 5 miles of Tynemouth should get it :-)
- fez
we are in the zzzzz.zapto.org room which is at the bottom. In the english room then head to the huntingdon room at the mo.
- MrWeetabix
- Admin
Welcome to the Node our first contact, Whistler from this forum!!! Pleasure to speak to you for the first time! :-)
- fez
Well the test worked a treat.
- MrWeetabix
- Admin
Looking forward to running this system 24/7
- MrWeetabix
- Admin
My node is online untill midnight tonight
Channel 31 UK muppets, May take it offline if abused.
Audible in Tynemouth, North Shields, Wallsend, Hebburn, Jarrow, South Shields, parts of Gateshead
- northern35s
Coming into this one a bit late, but where did you end up with it? I'd certainly like to know more and whether your trials were abused.
Mobile DXing from the car and on foot
