There appears to be a great many different handhelds advertised, the majority of which are UHF only, or VHF only. I have found one dedicated PMR dual-band handheld by manufacturer, Tritan, known as the 'Town and Country', but which has the disadvantage of only having a 2 watt output. I then came across the Baofeng radios, more specifically the UV5R, which is inexpensive and appears to be capable of 4-5 watts on both VHF and UHF.
However, the UV5R seems to be classed as a HAM radio, which lead me to wonder whether the Baofeng UV5R is actually legal for use under the terms of the UK Simple Light License.
From reading the specification of the UV5R, it appears to transmit on the VHF and UHF PMR frequencies covered under the terms of the license, but is also capable of transmitting on a lot of other frequencies too, none of which are covered under the terms of the license.
Wanting to be sure on this point, I sent an email to Ofcom, asking if they could please confirm the Baofeng transceiver as acceptable for use under the terms of the Simple Light license. They replied with the following answer
Ofcom cannot approve radio equipment as compliant or give advice. Ofcom is an enforcement authority. We do publish general guidance, like this document, about what responsible persons, like manufacturers and importers, must do to meet their responsibilities under the R&TTE Regulations. But, those persons are responsible for compliance and, if they need advice on that, should seek their own independent advice, preferably from a Notified Body.
Ofcom did suggest a couple of links to documents which I should refer, but even after reading these I still seem to be left with my original question unanswered.
I have read elsewhere on this forum that the UV5R is suitable for use under the PMR license, as it conforms to CE spec, but also read on another forum at http://www.bushcraftuk.com/forum/showth ... p?t=105512
Word of caution on the Baofeng UV-5r in the UK. These hand sets are not legal for transmitting in the UK but legal for reception. This is because the handset is able to transmit out of public bands on bandwidths that are controlled by licencing. You can find reputable UK suppliers that will sell these items so that they can only receive.
So, can anyone tell me what the real deal is with the UV5R and UK Simple Light? Legal or not
While on the subject of the UV5R, I have seen several variations of this handset, ranging from UV5R, UV5RA, B, C, E, I, +, etc, etc, and have read that the A is the most recent. While a seller from ebay has told me that they are all the same and only differ in terms of their physical appearance. I am guessing that in reality the firmware of the units is different? Is anyone able to confirm this?
Also, is it possible to obtain a 5 watt mobile (vehicle) PMR radio which can be used under Simple Light? Those I have seen so far appear to be 25 watt, and so presumably illegal for Simple Light use.
I hope someone reading this post can please assist with some constructive advice.
