Advice on Best Drill to use to drill hole for SO239 mount.
WeatherWatcher
Post by WeatherWatcher »
Ok I need to drill a hole in my car roof to fit a mount for my dualband antenna. Have found nothing in the way like ribs or wiring under the head lining but now need to purchase a drill bit 16mm dia for the one hole- what would people recommend?
Because it is almost centre of the roof longitudanally should be OK. I know about the getting a good earth bit and cleaning any burrs off the edge of the hole. Any other advice welcome.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Re: Advice on Best Drill to use to drill hole for SO239 mount.
Post by MrWeetabix »
16mm seems big.... double check that fella!
WeatherWatcher
SO 239 mount. Will get mount first and then sort out drill when confirmed size.
26TM931
Post by 26TM931 »
Oldman54 wrote:SO 239 mount. Will get mount first and then sort out drill when confirmed size.
you have a pm
dt307
Call Sign: 163dt307
Post by dt307 »
here you go
163dt307-chris
― Albert Einstein
Dragonfly
Call Sign: 26TM363
Post by Dragonfly »
If you have this type i think they need a 12mm DV connector hole http://www.thunderpole.co.uk/fixed-body ... t-kit.html
Check u have around 35mm space between head lining and roof .
WeatherWatcher
Thanks Dragonfly that is the mount I intend to use, getting it with mini 8 coax cable from http://www.4x4cb.com/ who are not too far away from me- local enough to arrange a pick up to save on carriage( tight wad that I am).
thedeerhunter270
Post by thedeerhunter270 »
stanogs68
Post by stanogs68 »
just hammer a six inch nail through it ,but use good heavy lump hammer to get it through with one all mighty smack
love your familly
porky.69
Post by porky.69 »
stanogs68 wrote:just hammer a six inch nail through it ,but use good heavy lump hammer to get it through with one all mighty smack
pmsl :lol:
vx900
Post by vx900 »
i use one of these they are excellent
http://www.ebay.co.uk/itm/16-to-60mm-93 ... NEXoFt1hDA
for roof's you might want to consider these
http://www.ebay.co.uk/itm/Q-Max-QMA16M- ... SwbYZXf2Uj
VintageTin
Call Sign: 26TM516
Post by VintageTin »
Q-max would be my preference, assuming a very low crown panel as, by the very nature of the way it works, it could locally distort any curved panel.
An ideal way of cutting accurate, clean, holes.
Malcolm
sec1223
Post by sec1223 »
stepped drill bit.. best idea
cant stand IGNORANT b******ds
ke7azd
Call Sign: ke7azd
Post by ke7azd »
Place duct tape over the head liner so it doesn't bunch up and rip / shred. I used these drill bits.
73's
grafter
Post by grafter »
When I did this to my Landrover I found the roof panel to be too flexible so added a sheet of aluminium underneath large enough to tuck under the nearest support rib that ran over the roof. This meant sourcing an SO239 mount that had a longer threaded section.
