DNT M40FM squelch stuck open
LondonCbRadio
Post by LondonCbRadio »
A while ago i bought a joblot of radios that wasn't working and DNT M40FM was one of them. The fault on it is the squelch stays open even when turned all the way up. I can't find a clear diagram on this radio does anyone have any idea ?
14CS06
Re: DNT M40FM squelch stuck open
Post by 14CS06 »
Hello
Schematic DNT M40FM
Claude
LondonCbRadio
Thanks alot. r47 was missing so i replaced that but still not working.I'll have another look when i get the time.
cubwolf
Call Sign: M3CBY
Post by cubwolf »
Notorious for dry joints especially on the through hole pcb links. It will more than likely be the MC3357 if chip at fault.
My lovely boss back in the day bought a thousand of them all returns that i had to look at when no other repairs came in the door
LondonCbRadio
cubwolf wrote: 08 Jun 2023, 19:38 Notorious for dry joints especially on the through hole pcb links. It will more than likely be the MC3357 if chip at fault.
This one has missing parts and wires cut. Any change you have a photo of one open the top side ?
14CS06
Post by 14CS06 »
Hello
Photos
Claude
LondonCbRadio
14CS06 wrote: 23 Jun 2023, 11:44 Hello
Photos
Claude
Thanks alot but i need photos of the other side of the board.
14CS06
Post by 14CS06 »
Hello
Only this one
Claude
LondonCbRadio
Thanks for that it looks like i'm missing a few parts.
LondonCbRadio
All the arrows are the part i'm missing along with a few missing wires. Do you know the value of these parts ?
LondonCbRadio
Anyone ?
bitbang
Post by bitbang »
Not all of the M40's have this modification, I have seen ones with no components on the solder side, a couple of parts and the full modification as per what Claude has posted. There are also component changes on the other side too. Just in case you have one with a different modification.
The values on a M40 I have here (which is identical to Claude's) are:
Hope this helps.
LondonCbRadio
bitbang wrote: 18 Aug 2023, 11:54 Not all of the M40's have this modification, I have seen ones with no components on the solder side, a couple of parts and the full modification as per what Claude has posted. There are also component changes on the other side too. Just in case you have one with a different modification.
Hope this helps.
Thanks mate i'll put them parts in and see if there is any difference.
