Warrington 455.750
Carlos
Call Sign: mm12
Re: Warrington 455.750
Post by Carlos »
I've found 440.225, 455.775, 453.9875, 445.6125, 455.750, also 456.975 (a warehouse or distribution centre, but which, there are loads around here) all on DMR, on 456.400 on NFM which is possibly a shopwatch in St Helens
DuncanM
Post by DuncanM »
You still haven't yet said which scanner you have. Some have continuous from 25 to 1300 mhz, some have gaps.
Carlos
Call Sign: mm12
Post by Carlos »
Bottom of page 1 the list with freq, ICOM IC R5
milly
Call Sign: redacted
Post by milly »
Carlos wrote: 14 Jan 2021, 22:43 I've found 440.225, 455.775, 453.9875, 445.6125, 455.750, also 456.975 (a warehouse or distribution centre, but which, there are loads around here) all on DMR, on 456.400 on NFM which is possibly a shopwatch in St Helens
Exact same text posted by someone else on another bulletin board......
'carlos' using an R5 but can determine that a dmr freq is a warehouse or distribution centre?
He can listen to paging data and say it's an 'airport'?
Anyone else find this rather suspect?
Metradio
Call Sign: G7HID
Post by Metradio »
Nowadays it is not unusual :-(
Mike
Carlos
Call Sign: mm12
Post by Carlos »
Hi everyone, is anyone having any luck receiving this? please PM or reply thanks
Carlos
Call Sign: mm12
Post by Carlos »
Hi all I have been doing some research as my laptop has packed up …. RADIO SCANNER - UNIDEN BEARCAT UBCD 3600XLT DIGITAL & ANALOGUE 25-1300 MHz Will this be any good for shopwatch that’s now digital?
Mototrbo2020
Post by Mototrbo2020 »
Carlos wrote: 17 Jun 2023, 09:30 Hi all I have been doing some research as my laptop has packed up …. RADIO SCANNER - UNIDEN BEARCAT UBCD 3600XLT DIGITAL & ANALOGUE 25-1300 MHz Will this be any good for shopwatch that’s now digital?
More than likely unless its something like Tetra but i very much doubt it.
Carlos
Call Sign: mm12
Post by Carlos »
Ah thanks mate I had an SDR unfortunately I didn’t get around to sorting it before laptop went south! Is an SDR worth it now? I will be replacing laptop it. I was the setup for the SDR that was the issue for me….. but given time I could set up
Mototrbo2020
SDR sticks are sill worth it. Cheaper than a scanner too.
DuncanM
Post by DuncanM »
Can you recommend a laptop you can fit in an inside pocket?
There is nothing on a database for 455.750 in Warrington or a 10 mile radius at least and when I'm there nothing shows up. 456.400 is the Ravenhead retail park security in Widnes. 455.6125 is down as a factory, a shopwatch in Runcorn (never heard it) or a factory. It's also a taxi company in Blackpool with a repeater on Winter Hill so covers a massive area. 455.775 is Amazon. 456.975 could be a number of things. 453.9875 is a common frequncy it could be Halton Hospital if you are hearing it on DMR or Wigan shops and pubs if on NFM.
440.225 could be Chester Zoo, a Heinz factory or something associated with Manchester airport
I can confirm some of the above and the rest through radioreferenceuk
