MIDLAND 747B-BOSTER?
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
Can anyone please give me any infomation on a midland 747b burner,what the output is on fm/sideband.
suealw
Call Sign: 2W0RBW
Re: MIDLAND 747B-BOSTER?
Post by suealw »
just googled it and a couple of sites are stating it does 100 watts am/fm and 200 watts ssb.
hope this helps. :)
2W0RBW
wa10
Post by wa10 »
warlock i have not seen one for years but the ones i have seen were the same as the cte 747, use 4x ms1307 mosfets making around 100w max fm or ssb with 10w input, they are not biased for ssb use and sound crap on ssb like any class c amplifier, a much better choice would be the rm-kl203 which are biased for ssb make a little more power and sound ok.
W8JI
UGLY_BOB
Post by UGLY_BOB »
wa10 wrote:a much better choice would be the rm-kl203 which are biased for ssb make a little more power and sound ok.
I totally agree with that. Mine's been excellent, and it doesn't get overly hot either. I think it's the mosfet tranny that makes it perform so well. ;)
EXTREMELY WEIRD... AVOID AT ALL COSTS !
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
i have been offered a k/po EA-150P any thoughts on this amp?
UGLY_BOB
Post by UGLY_BOB »
Had one a few years back. It was good. It's sold under a few names. Mine finally blew up though... whereas the RM stuff tends not to. ;)
Bulldog69
Post by Bulldog69 »
wa10 wrote: 02 Jul 2009, 18:24 warlock i have not seen one for years but the ones i have seen were the same as the cte 747, use 4x ms1307 mosfets making around 100w max fm or ssb with 10w input, they are not biased for ssb use and sound crap on ssb like any class c amplifier, a much better choice would be the rm-kl203 which are biased for ssb make a little more power and sound ok.
Bit late for a reply to this thread but the 747 has the RM 203 board inside 😂
