Anyone have newer than >Simoco Software v4.82
- mr_h4ck3rm4n
- Call Sign: MM6SGZ
Does anyone have software for the sepura/simoco srm1000 radios, i have Simoco Radio Programming Software - Sepura v4.82 (for Simoco Tetra SRP1000, SRP2000, SRM1000) but i have been told this is a realy old version and is causing me some problems with the radios crashing (displaying engineering mode) and also sometimes the radio will not allow a DMO call with the display showing 'calling...' instead of the radio displaying 'Talk..' and requires power off/on to reset.
cheers
cheers
HF
Ameritron 811, Yeasu FL2100
VHF/UHF
Icom IC-208H, Icom IC-2820
Jotron TR7550 VHF Air
Antenna
Data Interface
QRZ.COM
- mr_h4ck3rm4n
- Call Sign: MM6SGZ
Re: Anyone have newer than >Simoco Software v4.82
Radios now working after firmware upgrade,
info that came with .drm file -- :
SRM1000 low tx power, about 1 Watt, 1amp drawn, after customising with
V4.40 or later Dealer software.
Radio has old firmware:
Main Micro Boot Code 4313 327 84409 (this was on my radios)
Main Micro Code 4313 327 84745 "" ""
Console 1 Code 4313 327 84396
Mobile Transceiver Authentication Code 4313 327 84273
Solution: download new firmware MN45V013 using programmer
Anyone having similar problems with ex dolphin tetra srm1000's pm me and i will forward newer s/w and firmware, it seems dolphin did not use direct mode and had the software on the radio customised with some of the parameters removed.
cheers
cheers
HF
VHF/UHF
Antenna
Data Interface
QRZ.COM
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0367531823
He also has the .DRS file MNV46B005 and PNV46B005 for the SRM and SRP1000
73 Oliver
- mr_h4ck3rm4n
- Call Sign: MM6SGZ
someone else emailed me about the ex dolphin srm1000's , they had got a few and got the v6.x.x software but it would not work with them, i sent the older software and all was fine after the firmware update.
i am having a nightmare finding the oldest cps for the mth800 at the moment.. mr5.1??
HF
VHF/UHF
Antenna
Data Interface
QRZ.COM
- New User
Hi, I could do with the firmware to prog my SRM1000's (Ex Dolphin) to support DMO. I have the programming software V4.8.9 but didn't have the firmware upgrade.
regards eproducer
regards eproducer
- New User
Hi mr_h4ck3rm4n,
Tried PM'ing you and get a message saying "you are not permitted to email this user". Also seem to be having probs with posting a msg to this site too! Let me know if you get this OR that you got my PM.
eproducer
eproducer
- New User
Hi mr_h4ck3rm4n,
eproducer
eproducer
It's due to your membership status, being 'registered' only somewhat limits you (posts pre-moderated, no PM's, etc.)
hello give me MN45V013 or MNV46B005yu
after a power repair, the srm1000 reports incomplete software. I suspect data corruption 28f800. boot I work
found it myself. put it here
thanks for the archive, im new in srm1000
