What CB radio to buy
Hello again to all.
I can get the President Lincoln 2+ and the President MckLnley locally
and they are the same price.
I like the many features of the 2+, but the McKinley seems to be a popular
CB too.
Which would you go for, and what are the main differences / advantages
of one over the other, there is no clarifier on the McKinley which is why
I like the 2+ , unless I picked it up all wrong the clarifier is there to adjust
the transmit or receive frequency in the event the radio's transmitting or
reception is off line with what it should be doing, hopefully someone will
put me straight on this.
Thanks for looking.
CB too.
Thanks for looking.
- Tin soldier
Re: What CB radio to buy
Not had either but the McKinley does have a clarifier,. Think they both only work on RX.
- Call Sign: 26TM773
I've got both radios and they are both great, however, the McKinley is very fiddly to operate mobile and the Lincoln can't be programmed for UK frequencies easily, so I'd not recommend either for mobile use.
I'd choose a Grant 2 anyday over either of those for mobile use.
- Mudslinger
The KcKinley is the one which I would choose.
Having said that I don't like the way the front mounted speaker pushes all of the controls in a small area to one side.
If they had used the board in a radio with an underslung speaker and better spread out controls it would be a winner.
I have had a couple of Grant 2's and some of the other radios which share similar boards to the Lincoln 2 and I wasn't impressed with them.
- Call Sign: 108tm1313
Would look at the Albrecht 5890eu as another option, compact and easier to use as well.
Thanks, seems like this is quite an old radio by now.mrpsychopath wrote: ↑25 Feb 2023, 17:13 Would look at the Albrecht 5890eu as another option, compact and easier to use as well.
- lambrettadave
- Call Sign: TM455
And cheapermrpsychopath wrote: ↑25 Feb 2023, 17:13 Would look at the Albrecht 5890eu as another option, compact and easier to use as well.
Thanks for posting, good to know a clarifier is available.Tin soldier wrote: ↑25 Feb 2023, 07:53 Not had either but the McKinley does have a clarifier,. Think they both only work on RX.
True, controls must be fiddly with them pushed together on the McKinley.Mudslinger wrote: ↑25 Feb 2023, 14:35 The KcKinley is the one which I would choose.
- lambrettadave
- Call Sign: TM455
The McKinley has true span feature but the frequency display is small.
The rig does take a bit of getting used to though once mastered it is a nice set.
Have you considered any of the CRT rig's..... They are about £100 cheaper.
Or how about the new superstar 3900...
Food for thought
Food for thought
Thanks for posting. I had thought of the CRT 7900,lambrettadave wrote: ↑25 Feb 2023, 21:25 The McKinley has true span feature but the frequency display is small.
Food for thought
in Ireland they are not available, I have to import one
and that leaves them just as expensive as the Presidents.
I opted out of this, because I was under the impression the Presidents
were a better built set than the CRT 7900, am I wrong about this, I like
the 7900 better but its so close to the price of the presidents,
being new to this, I need the advise of others,
I can't get a hands on the 7900 without buying one first.
- lambrettadave
- Call Sign: TM455
I suppose it comes down to what you want to use the radio for.....
Alot of folks are liking the latest range of CRT rig's.
I personally would buy the McKinley. I enjoy mine in the house and static mobile in the car. The grant2 display and button layout is better but doesn't have span and mine puts out about 8 watts where as McKinley does 25 watts
Thanks for posting. Does your McKinley have a single knob clarifier, or course and fine.lambrettadave wrote: ↑25 Feb 2023, 23:30 I suppose it comes down to what you want to use the radio for.....
Am reading people have noise / hiss coming from the speaker even when silenced,
and some are having clicks pops and such when moving the squelch manually.
- lambrettadave
- Call Sign: TM455
All EU/UK versions have a single clarifier
Check this out
https://youtu.be/zJZXYSSULLY
This is my radio in the car I have posted other videos so you can check them to
Check this out
Thank you for posing, I appreciate the link, will check it out.lambrettadave wrote: ↑26 Feb 2023, 23:40 All EU/UK versions have a single clarifier
Check this out
Question if you have the time, if you had to buy again would you make the same choice of CB,
or has something else come along you would consider, thanks.
