dPMR
- dcwuk
Re: dPMR
Amazon have Kenwood TK-3701D and Retevis RB22
both also available elsewhere search for them by name.
- Call Sign: 26DG01
Re: dPMR
Try looking for some old Icoms, their iDas range is dPMR. I bought some scrap IC-4062 handhelds which can do dPMR with the addition of the dPMR option board.
Sent from my GP300 using DTMF
Re: dPMR
The reason I am looking dpmr is I was sitting outside
our local supermarket beginning with L .i was listening
on 446 on my SDS 100E and off cores they are using Bluetooth
and scrambled so I am hoping that dpmr will allow me to
receive them in the clear.
- Call Sign: 26TM9500
Re: dPMR
Dave, if you're talking about Lidl, on Channel 3, it's not dpmr that they use. It's "voice inversion". If you do a Google search, I'm sure there will be some sort of Windows software that will decode it for you. Although, all they'll be talking about is stock movement.
CRT SS 6900
President Lincoln I
Maxcom-20E
Motorola DP4600e
Retevis RT40
Retevis RB618
AOR AR8000
Binatone Action 950
Degen DE1103
RTL-SDR
26-TM-9500 26-CT-9500
Monitoring 27.555 USB, CH19 + CH25 - UK40fm and Ch08 Pmr446
President Lincoln I
Maxcom-20E
Motorola DP4600e
Retevis RT40
Retevis RB618
AOR AR8000
Binatone Action 950
Degen DE1103
RTL-SDR
Re: dPMR
Also Dave you can't hear there bluetooth headsets audio on a radio or a scanner and a dpmr radio definitley won't recieve that either , analogue voice inversion tho is different and easily listened to as others have said .
- Metradio
- Call Sign: G7HID
Re: dPMR
If you still have your DV-10, it will handle voice inversion..
Mike
Mike
