I've been investigating. Not speaking from first hand experience, but my understanding from colleagues across the pond is that it cannot decode RAS-enabled systems in scan mode, and definitely not trunk track a RAS-enabled CAP+ system. It can decode RAS if the scanner is sat on a specific frequency. Seems like it has some catching up to do vs. where Uniden is.moj wrote:Thanks for that jim , next question is do we know yet if the whistler range has the same feature with scanning ras enabled transmissions or is it only the unidens that can do this ?
warrington shop/pub watch no more
Re: warrington shop/pub watch no more
- Been thanked: 1 time
I wonder if any uk dealers are considering selling the uniden digital scanners then like the whistler range that has appeared here in the uk , would be a cheaper option for us users instead of buying from the states , fingers crossed anyway jim
Hi found a couple of posts on this, whats the best way to recieve? SDR or a DMR radio? or an expensive scanner?
A laptop can be expensive and doesnt fit inside a jacket pocket or clip to your belt well. Warrington shops and pubs were still on dmr 3 weeks ago, I'll be there tomorrow and listen out for them. The shopping centres there I think are downfire which means they dont transmit over any real distance just more or less within the shopping centre
