DMR Frequencies.
DMR Frequencies.
Any DMR Frequencies in Glasgow and surrounding area. Thanks.
- spykeboi
- Call Sign: MM6SPY
- Call Sign: 108AT106
Re: DMR Frequencies.
Most of the guys on here are wide enough not to post what little "DMR frequencies" there are left to listen to and rightly so . Soon as they're posted in the open and the company / business / supplier spots them , it is usually always the same story ...calender material until encryption.
Let your scanner do the work , use its search facility to see what's around you . Gone are the days we had to toil and find modes , tones , steps .
Today's scanners do it all and if youre asking for dmr frequencies I'm assuming you have a digital scanner ? Dont be lazy ..Get searching, let it search for hours , take it out and about with you if you can , if you don't hear much try another antenna , there is stuff out there . But whatever you do .. don't video/post your findings is my advice. Share your findings wisely . DM other members who are into the hobby from your area and swap.
Remember scanning is a dying past time we have to preserve what we are listening to or it will end up being only Clyde 1 and VHF on a £400+ radio .
Good luck
Good luck
Kind Regards
Rab
Rab
